users not pulling great speed on AP-225 system
  • 1.  users not pulling great speed on AP-225 system
    Posted Apr 09, 2016 04:19 PM
    I have just started using Aruba AP-225's and have them paired with Juniper 48port poe+ switches.
     Now I have 9 APs deployed with about 500-600 users that are byod, we deployed this system in a Art building that is used as event space.
    I had 400 down/ 40 up from the modem. I had users seeing 0.1 mbps to 20 mbps, I have 7 ssids and each on different Vlans with speeds being limited  (2up/2down for guest, 2up/10 down for employees,  2up/20down for my team, etc) I figured it was due to the users grabbing an AP that was too far from them.
    How can I setup the system so that users will not pull a slower/weaker signal and have slow speeds?
    I want the best experience for everyone in the events we do, I have attached what the layout is and our AP placement
  • 2.  RE: users not pulling great speed on AP-225 system
    Posted Apr 09, 2016 04:38 PM
    Please see the post here http://community.arubanetworks.com/t5/Technology-Blog/Removing-the-Bottleneck-in-Wireless/ba-p/77978
    Two comments: you should limit your number of SSIDS to 4 or less. Any more than that hurts performance significantly.
    - you should remove your bandwidth contracts so you understand the true performance of your network.
  • 3.  RE: users not pulling great speed on AP-225 system
    Posted Apr 09, 2016 07:21 PM
    Thank you for the suggestions
    Is there a guide for for they type of environment that I am trying to create?
    My main issue with limiting the SSID count is that multiple clients of ours request specific SSIDs for their events that we host. Also with that request is seperate networks for each so we use Vlans.
    Here is an example of what we have done
    SSID: Vlan
    Guest: Vlan 15
    Employee: Vlan 3
    Press Media: Vlan 12
    VIP: Vlan 11
    Cafe: Vlan 5
    POS: Vlan 13
    Audio: Vlan 14
    Management: default vlan
  • 4.  RE: users not pulling great speed on AP-225 system
    Posted Apr 09, 2016 07:23 PM
    Is there a AAA server for the Employee SSID?
