Occasional Contributor I
wifi users disconnect
All of a sudden a problem occured on one of our controllers. it was working fine and to my knowledge no changes has been made.
I started with looking through the log and I spotted a few errors that seems to coincide with the problems I have. I tried google but that give me nothing.
Apr 25 13:56:45  KERNEL(APOSTE28002@10.155.5.101): RESTARTING ALL TX
Apr 25 13:03:54  KERNEL(APOSTE59315@10.155.5.102): vap aruba101 vlan is 0. discovering tunnel vlan
Could someone inform me about what they mean and for what reason they might appear?
Re: wifi users disconnect
discharged wrote:
That message is inconclusive.  Please get the logs and technical support from the Maintenence Tab ASAP before more time expires and the logs wrap.  Open a case and attach the logs and technical support to it.
Frequent Contributor II
Was there any solution to this problem, i'm facing the same error messages and clients disconnecting.
Roar
Roar
Every situation has its own specific issue.  Please take a look at the RF troubleshooting methods in the thread here:  http://community.arubanetworks.com/t5/Community-Knowledge-Base/802-11-RF-Troubleshooting-Best-Practices/ta-p/20410
