Wireless Water Cooler
How do I add a user rule via the cli?
I am new to all things Aruba. What I'm trying to do is add a user rule via the command line. I just don't know what the command is. I took a look at the manual, but I might not be looking for the right keywords as I couldn't find it. Aruba OS is version 6.3.1.8. If I didn't post this in the right forum, please move it or alert me and I'll repost in the appropriate section.
Thanks in advance.
Aruba
Re: How do I add a user rule via the cli?
What exactly are you trying to create?  This chaper on Roles and Policies should help get you started.  You'll need the PEFNG license for it to work.
http://www.arubanetworks.com/techdocs/ArubaOS%206_3_1_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/Firewall_Roles/Firewall_Roles.htm
AMFX | ACCX | ACDX | ACMX
Thanks for the reply. Basically, I am creating a web form where users can register their wireless devices with the Aruba controller. So I want to write a script to SSH into the controller and run the command to add a user rule.
Also, I'm looking to add a user rule not a user role.
(config) #aaa derivation-rules user <udr-ruleset-name>
 set role:
(user-rule) #set role condition <bssid,dhcp-option,dhcp-option-77,encryption-type,essid,location,macaddr> <contains,ends-with,equals,not-equals,starts-with> <value> set-value <role-name>
set vlan:
(user-rule) #set vlan condition <bssid,dhcp-option,dhcp-option-77,encryption-type,essid,location,macaddr> <contains,ends-with,equals,not-equals,starts-with> <value> set-value <vlan>
Keep in mind that this was not designed to be a registration-type feature. It was designed to take groups of devices that share common properties and assign a role (for example, the DHCP fingerprint of game consoles, or the MAC prefix of a VoIP phone). You may run into scalability issues.
Tim Cappalli | Aruba Security
