Wireless Water Cooler
last person joined: 17 days ago
Hang out and socialize with other community members in this off topic forum. Everything from industry trends to hobbies and interests are welcomed!
MVP Guru Protip 001
  • 1.  MVP Guru Protip 001
    Posted Sep 12, 2013 06:35 AM
    Hi All,
    Thought you might like this....
    When on a remote session with a customer try not to mistype commands. This is especially important when checking that the time and date is correct as I found out yesterday.
    (A3200) #show clock
    That's the command. Do not under any circumstances attempt to run this command without the "l" in clock as this will likely not get you the information you were looking for.
    That's all for now.
    Cheers
    James
  • 2.  RE: MVP Guru Protip 001
    Posted Sep 17, 2013 10:19 AM
    I guess it got you and your customer a good laugh though ;)
    Chris
  • 3.  RE: MVP Guru Protip 001
    Posted Sep 17, 2013 10:38 AM
    Yeah we had a chuckle. :smileyvery-happy:
  • 4.  RE: MVP Guru Protip 001
    Posted Sep 19, 2013 12:28 AM
    hahahahah that was soo funny...
