IAP MAX AP per Cluster ?
  • 1.  IAP MAX AP per Cluster ?
    Posted Nov 10, 2014 07:32 AM
    hi
    what is the MAX number of IAP per cluster for all Aruba access points ?
    i want to know max number regarding to IAP-103 but
    please advice for all Aruba IAP series .
    Best regards,
    Ehab Atef
    Network Engineer
  • 2.  RE: IAP MAX AP per Cluster ?
    Posted Nov 10, 2014 08:10 AM
    The recommend max is 125 .
    But if you have an AP9x connected to your cluster it will reduce it to 16
  • 3.  RE: IAP MAX AP per Cluster ?
    Posted Nov 10, 2014 09:02 AM
    It is unlimited but best practices need to be followed such as not surpassing your broadcast domain addressing.
  • 4.  RE: IAP MAX AP per Cluster ?
    Posted Nov 10, 2014 09:44 AM
