IAP GUEST, Captive portal (masqueraded)
  • 1.  IAP GUEST, Captive portal (masqueraded)
    Posted Jan 02, 2015 10:48 AM
    Hi all,
    I'm running around in circles here. Hope you guys can help.
    - My IAP guest setup places guest users on a seperate VLAN that has no route to the internal network.
    I have configured an external captive portal for the guest ssid.
    I have created a role (pre-logon) that allows a sourcenat to the CPPM server.
    If I connect to the guest ssid, I receive a correct network-issued IP address.
    If I start a web browser and point it to a random site, I am redirected to the URL configured in the external caprive portal setting. The browser then times-out. No traffic is received from CPPM. The redirect is setup for http port 80, clearpass then should redirect to 443.
    I can however ping the CPPM server.
    If I test this in a vlan that is allowed to route to CPPM, all works fine. Somehow the IAP is not handling my traffic properly. Some config snippets below.
    This is driving me nuts! Please help. Thank you!
    wlan external-captive-portal Guest_portal_nl
    server nac-portal-nl.mydomain.com
    port 80
    url "/guest/taqa_guest_register_IAP_login.php"
    auth-text ""
    auto-whitelist-disable
    wlan ssid-profile TQ_GUEST
    enable
    index 1
    type guest
    essid TQ_GUEST
    opmode opensystem
    max-authentication-failures 0
    vlan 25
    auth-server CPPM-NL
    set-role-pre-auth TQ_GUEST-PREAUTH
    rf-band all
    captive-portal external profile Guest_portal_nl
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter arp
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    max-clients-threshold 64
    auth-survivability cache-time-out 24
    wlan access-rule TQ_GUEST
    index 4
    rule any any match any any any permit
    wlan access-rule TQ_GUEST-PREAUTH
    index 5
    rule 10.220.207.9 255.255.255.255 match any any any src-nat
  • 2.  RE: IAP GUEST, Captive portal (masqueraded)
    Posted Jan 02, 2015 11:31 AM
    does the CPPM have a route back to your client subnet?
  • 3.  RE: IAP GUEST, Captive portal (masqueraded)
    Posted Jan 03, 2015 09:26 PM
    I have this issue and I think it is a bug in IE or how the CP redirect is done on IAP, if you use HTTPS with port 443 under your CP profile of your IAP you will see it will work.
    I have noticed this behaviour only with the latest IE. You will not see this issue with Firefox or with Chrome when port 80 is configured in IAP.
  • 4.  RE: IAP GUEST, Captive portal (masqueraded)
    Posted Jan 03, 2015 09:33 PM
    Thanks for the note. Please open a TAC case so we can track the issue.
  • 5.  RE: IAP GUEST, Captive portal (masqueraded)
    Posted Jan 05, 2015 03:47 AM
    All,
    I have a macbook. tried it with Safari/Chrome 7 firefox.
    CPPM has no toute to the guest network, hence the src-nat rule.
    I fiddled around with 443 & 80, that did not seem to help. i'll try again tomorrow when I'm on site.
    Leo
  • 6.  RE: IAP GUEST, Captive portal (masqueraded)
    Posted Jan 05, 2015 09:57 AM
  • 7.  RE: IAP GUEST, Captive portal (masqueraded)
    Posted Jan 05, 2015 12:57 PM
    sure, but it does have one to the the IP the traffic is NATed to?
  • 8.  RE: IAP GUEST, Captive portal (masqueraded)
    Posted Jan 06, 2015 02:55 PM
    Hi All,
    CPPM does have a route to the AP's management address (& the VC address).
    We performed some wireshark traces (at both ends of the AP) and the AP does not seem to NAT the traffic. the source address is still the guest's machine and not the AP despite the srv-nat rule.
    - If I let the AP assign IP addresses, it works like a charm. I wiresharked the DHCP offer packet. Nothing strange found.
    COUNTERINTUITIVE:  >:\
    - I addedd the CPPM hostname to the walled garden.
    - I changed the src-nat rule to base itself on a domain (FQDN in this case) opposed to an ip address.
    It now seems to work.
    I will backtrack tomorrow, to see which change actually solved this and report back.
    Leo
