AAA, NAC, Guest Access & BYOD
Clearpass, CPPM, OnBoard, OnGuard, Guest, QuickConnect, AirGroup, IntroSpect
How to reset Ambari Admin password?
By esupport Unpublished
Access to Analyzer Cli and Ambari Cluster management console via port 7183( https://<Analyzer IP>:7183)
If you dont have the "admin" password to login to Ambari UI, you can follow the below instructions to reset the password.
You can use ambari user __niara and password is the contents of the file /etc/opt/niara/analyzer/security/__niara-pwd to login to Ambari UI for resetting the "admin" user password.
Login to Analyzer cli and ‘cat’ the above file.
[root@ ~]# cat /etc/opt/niara/analyzer/security/__niara-pwd
b35e81fb-f07c-4bb9-90eb-98377d0f101c
Then cut-n-paste that as the password for user __niara (note the 2 underscores)
Once you are logged into the Ambari using __niara user account, click on user "__niara" on the right hand top corner and click on "Manage Ambari":
Click on Users under "User + Group Management" and click on "admin" user:
Click on "Change Password":
Enter "Your Password" as "__niara" password and configure "New User Password" as the new password for this "admin" user and click on "OK" to finish:
Login to the Ambari UI with the new "admin" password created in the above process to confirm its working.
