Q: How TACACS Authentication & Authorization works in ClearPass Cluster
A:
- TACACS Authentication and Authorization works within the node.
- It will not be synced across cluster node.
- If TACACS Authentication request goes to Node1, subsequent Authorization request should go to the same node.
- If the Authorization goes to different node then it will not authorize the request.
- Also, ClearPass cache username with device IP for 24 hours.
- This will be configured under Administration » Server Manager » Server Configuration » Select the server » Service Parameters » Select Service: TACACS Server
- TACACS+ Profiles Cache Timeout
- This profile cache also within the ClearPass node only.
