Blogs
ArubaOS Downloads
By JuliaOstrowski posted Aug 06, 2014 12:50 PM
Files contained in the ArubaOS folder include multiple downloads.
Download latest software here:
AOS 6.1.3.14
http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=8804
Early Deployement Release 6.4
http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=10428
General Availability Release 6.3.x
http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=12918
Technology Release 6.4.0.2-HDMS
http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=13844
23 comments
Comments
Mar 24, 2020 10:17 PM
The following forum is informational and explanatory.Even I am also searching for this type of following update.I want to include I was not getting at all any image when I am adding the Intensity Shuttle as a shot in Wirecast 8.3, in Black Magic Media Express.For a couple of weeks I am facing the signal issues with both Arlo Ultra and Blackmagic.I have followed the suggestions as guided and also the manuals as directed by the arlo app for pc .Suggest us what to include into it.
Apr 27, 2018 05:48 AM
To william87283, BK
Can't you find over 10MB files at below?
http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=25165
I can find firms and release notes, still.
If you can't find anything, I don't know why you can't.
BTW, OS 6.x are for IAP or AP(2xx,3xx), OS 8.x are for Controllers(7xxx), I think.
I am also in trouble with this site. ;-(
I hope this site will be improved soon.
Apr 26, 2018 06:00 PM
Same as above, new to Aruba, and the common sense is not working on the portal. It is not intuitive to find release notes, latest software/firmware versions, etc. Just for the record we do have current support/maintanance agreement. The product is great but the website is just the opposite. Can someone point me in the right direction. Thank you.
Apr 17, 2018 06:28 AM
Hi there
I would like to know how to find the lastest firmware version and where to download it.
Because above link has already missed.
By the way, what is the difference of the OS8.X and OS6.X, for different device or other reason?
Feb 22, 2018 07:10 AM
hi all,
i got IAP-207 recently.
that's package is sealed "6.5.4.3", it is that AP's firmware version, i think.
but there is "6.5.2.0" in ArubaOS's repository.
which is the real and newest version?
and, is there newer one then "6.5.4.3"?
Sincerely,
Jan 31, 2018 08:08 AM
hi Huygens
is something new in 6.4.3.3 ?
thanks
Jan 26, 2018 03:00 AM
no,the newer one is 6.4.3.3
Jan 25, 2018 02:00 AM
hi all,
i have aruba controler 620
ArubaOS (MODEL: Aruba620), Version 6.3.1.24
Website: http://www.arubanetworks.com
Copyright (c) 2002-2017, Aruba Networks, Inc.
Compiled on 2017-02-06 at 03:18:37 PST (build 58295) by p4build
is newer version out for this controller?
thanks
Dec 27, 2017 04:41 AM
How can i download ArubaOS 8.2 OVA File For Test?
Oct 19, 2017 01:22 PM
Is there a software update/patch for the 3200 controller to beat the recently announced KRACK WPA2 vulnerability?
Oct 16, 2017 01:44 PM
Is there an inexpensive option for downloading an OS update for a 3200XM controller? I purchased a 3200 XM controller to learn how to program it, but I really dont need a support contract for it. It is for personal use only.
Any help would be greatly appreciated.
Best Regards,
Ken
Sep 28, 2017 04:09 AM
I need AOS 6.4.1.0 for aruba 650 mobility controller device to connect it to aruba ap 205, i have 1 aruba 650 mobility controller and 8 aruba ap 205 units, please help to send ARUBA OS 6.4.1.0 file for both types of devices via email to bajaklangit@gmail.com because I failed to download through the web support aruba network, some time I tried to login or register in order to enter the download page but failed. thanks.
Apr 24, 2017 03:38 PM
I need some help with figurating out the upgrade path for our APs. We are currently on 6.3.1.8-4.0.0.11_51202 and would like to upgrade our devices to at least version 6.3.1.15 or 6.4.2.4. There are differnt image files for differnt series of controllers. I just took over the management of our APs and I am not familiar with our hardware and the Aruba Central UI doesn't seem to have the controller versions. Could you please help me to get started with the upgrade? Any help will be greatly appreciated.
Feb 24, 2016 12:40 AM
can you please help me I have an Aruba AP 225 and users keep loosing connection. can you please allow me to donwload the latest firmware.
Oct 07, 2015 10:21 AM
I need the latest aruba ap105 firmware.  We are currently on 6.4.2.3-4.1.1.3_48994.  We are having issues with Windows 10 users showing limited connectivity for some reason.
May 26, 2015 06:16 AM
Is there something i can subscribe to that will give me information on what the current recommended release for the Aruba Controllers is? Our Airwave and Clearpass platforms tell me what the latest version is, but the controllers don't have this function and other than phoning our support partners helpdesk and asking if a newer version is out i don't know of an easy way of seeing if i should be upgrading or if there are security updates needing applied.
thanks.
Mar 06, 2015 05:13 PM
 Hello Daj, all the links above are working for me...can you please let me know if you are having difficulty just getting into the support portal?  Is it just that one link that doesn't work for you (for example, can you get into this link: http://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=13844
Thank you,
JULIA OSTROWSKI
OPERATIONS ANALYST  |  CUSTOMER ADVOCACY SALES OPERATIONS
M: 408.396.9193  |  @JULIAOSTROWSKI
1320 ORLEANS DR  |  SUNNYVALE, CA 94089
Mar 06, 2015 05:08 PM
 Hi Jonathan, unfortunately our software downloads are (for the most part) only for our customers with a valid support contract. If you would like a member of our sales team to contact you, please let me know (or click the orange button on the top of the page to contact our Sales experts.
JULIA OSTROWSKI
Mar 06, 2015 09:52 AM
The link for the AOS 6.1.3.14 download leads to an error page
Feb 27, 2015 05:10 PM
When I follow any of those links it sends me to a Register / Log in screen. When I click on Log in nothing happens. This is very frustraing I have created 2 different accounts so far and I'm not able log back into any on them
Jan 29, 2015 01:17 AM
 Hello nokia610, you should be able to download the appropriate software from our Support site. If you are having difficulty logging into our Support site (http://support.arubanetworks.com/), please email me and I can help you out.
Thank you,
Julia Ostrowski
jostrowski@arubnetworks.com
Operations Analyst  |  Customer Advocacy Sales Operations
Jan 28, 2015 11:29 PM
Hi all,
I need a ArubaOS for 620 controller Aruba, please help me.Thanks very much
