02.1x authentication with username/password on Internal DB
  • 1.  02.1x authentication with username/password on Internal DB
    Posted Mar 08, 2014 02:39 AM
    I would like to do a 802.1X authentication with username/password on Internal DB.
    Following username, I would like to allow the right vlan, I have 4 vlans.
    I have already added the names and passwords of the users to be authenticated in Internal DB and I put different role following username. with different vlan.
    I already configure AAA profile with Server group (Internal) and I enable termination to finish authentication on controller.
    But I don't know how I can configure default-role and 802.1X Authentication Default Role.
    Thanks for your help
    cCIl
  • 2.  RE: 02.1x authentication with username/password on Internal DB
    Posted Mar 08, 2014 06:13 AM
    The default 802.1x role is in the AAA profile.
  • 3.  RE: 02.1x authentication with username/password on Internal DB
    Posted Mar 09, 2014 09:09 AM
    On Internal DB, I configure :
    aaa server-group "interne"
       allow-fail-through
     auth-server Internal
     set role condition User-Name contains "ccil" set-value ccil-vlan4   : in fact, I will configure all users on Internal DB with different vlans
    aaa profile "Entreprise_AAA"
       initial-role "Entreprise_role"
       authentication-dot1x "Entreprise_dot1x"
       dot1x-default-role "ccil-vlan4"
       dot1x-server-group "interne"
    aaa authentication dot1x "Entreprise_dot1x"
       machine-authentication enable
       machine-authentication machine-default-role "Entreprise_role"
       machine-authentication user-default-role "ccil-vlan4"
       termination enable
       termination eap-type eap-tls
       termination eap-type eap-peap
       termination inner-eap-type eap-gtc
       termination inner-eap-type eap-mschapv2
    Someone can explain me each role :
    With different vlan, I cannot understand where I have to configure the server derivation and how.
    cCil
  • 4.  RE: 02.1x authentication with username/password on Internal DB
    Posted Mar 09, 2014 09:17 AM
    Two words of advice:
    1- Turn off (Enforce) Machine Authentication (machine authentication and Termination don't work.  You also are not going to put a machine's credentials into the internal database, so don't bother.  Enforce Machine Authentication is an advanced topic.)
    2- The commands that sets the 802.1x role  is below:
     3 -
    initial-role "Entreprise_role"   - Initial role for AAA profile.  Only valid for PSK or Open SSIDs.  NOTused for 802.1x
    dot1x-default-role "ccil-vlan4"  - Basic Role for when a client passes 802.1x
    (Enforce) Machine Authentication - Only in effect when Enforce Machine Authentication is activated.  Does not work with Termination, and is not used when Termination is off.
  • 5.  RE: 02.1x authentication with username/password on Internal DB
    Posted Mar 10, 2014 05:26 AM
    Thanks for your help.
    I have a question about vlans. Do you think I can allow specifc vlans following username when I used the same SSID and the same authentication ?
    cCil
  • 6.  RE: 02.1x authentication with username/password on Internal DB
    Posted Mar 10, 2014 06:19 AM
    ccil,
    Do you want:
    If X user authenticates, let them go to VLAN Y?
  • 7.  RE: 02.1x authentication with username/password on Internal DB
    Posted Mar 10, 2014 06:38 AM
    I have 80 users with 4 vlans :
    users1 => go to vlan 10
    users2 => go to vlan 20
    users3 => go to vlan 30
    with only 4 vlans not more
    cCil
  • 8.  RE: 02.1x authentication with username/password on Internal DB
    Posted Mar 10, 2014 07:08 AM
    ccil,
    Before I answer your question:
    - Is this to replace an existing system?
    - Are you using VLANs for security or access?  If so, what type?
