Wired Intelligent Edge
10.13.1030 on 8360 not using new static routes - requires reboot
  • 1.  10.13.1030 on 8360 not using new static routes - requires reboot
    Posted Aug 06, 2024 12:27 PM
    Edited by Keyser Aug 06, 2024 01:58 PM
    Hi all.
    Have a couple of 8360's in VSX running 10.13.1030  and any static routes I add are not activated.
    When i use show run, the routes are there, but using "show ip route" shows they are not activated, and therefore the default route is used instead.
    Is there something I need to do to activate a static route - Not even a reboot adopt the new route, it just shows in config.
    Is it a bug in 10.13.1030?
  • 2.  RE: 10.13.1030 on 8360 not using new static routes - requires reboot
    Posted Aug 06, 2024 02:09 PM
    I found the culprit. I had a mirror session running using the VLAN that has the SVI interface used for the new static route.
    That apparantly prevents the route from activating. Disabling the mirror session, removing the static route and adding it again activated it instantly.
    I could then enable the mirror session again.
