And if they don´t we will eaily find another switching platform for you serving your needs. So, please give some infos:
- budget:
- access/distribution/core/datacenter switch?
- amount of 10Gbe ports?
- amount of 1Gbe ports?
- dual fabric?
- Amount of virtual routing instances?
- which unicast/multicast routing support within routing instances?
- integrated NAT?
- integrated stateful firewall?
- integrated IDS?
- integrated IPv6 firewall?
- routing table size (IPv4)?
- routing table size (IPv6)?
- IPv4 routing? BGP, ISIS, OSPF, RIP, static?
- IPv6 routing? BGP, ISIS, OSPF, RIP, static?
- multicast: PIM-DM, PIM-SM, PIM-SSM?
- IPv6 multicast: PIM-DM, PIM-SM, PIM-SSM?
- MPLS?
- VPLS?
- Running VPLS over GRE tunnels?
- VXLAN?
- TRILL?
- SPB?
