15 AP instant network showing 100% on AP's
  • 1.  15 AP instant network showing 100% on AP's
    Posted Dec 11, 2012 11:17 AM
    Hi All,
    I am currently installing a 15 AP instant network and while looking at a roaming issue I noticed that all the Instant AP's are pegged at 100% CPU! Except the AP currently assigned the role of the virual controller.
    Simple WLANS 1 corporate network (default VLAN), 1 guest network (currently not being used specific VLAN) and another corporate network(default VLAN) used for Motorola MC9090's
    I am seeing 100% CPU even on AP's with no clients!
    Has anyone seen this before ?
    FW: 6.1.3.4-3.1.0.1_35899
    Any help appreciated.
    Dave
  • 2.  RE: 15 AP instant network showing 100% on AP's
    Posted Dec 21, 2012 09:34 AM
    Worked it out in the end 2 of the AP's had the same static IP assigned!!!
