Comware
1950 JumboFrames
  • 1.  1950 JumboFrames
    Posted Apr 13, 2016 09:23 AM
    Got a few HP 1950 switches, mixed with some Cisco and Ubiqutii gear.  All works fine with VLANs etc.  But I can't get the HPs to do jumbo frames.
    Under Network->Interfaces I can set the frame size for each physical interface (max 9216).  But that doesn't apply to the VLANs and has to be done seperately.  So I go to Network->IP and select the VLAN interface, but find the max allowable MTU is 1500.
    Am I missing something, or is jumbo frames only supported if not using VLANs?
    #frame
    #MTU
    #VLAN
    #9216
    #1500
    #9000
    #1950
    #jumbo
