2 SSID's & 2 ISP's
  • 1.  2 SSID's & 2 ISP's
    Posted Feb 22, 2016 09:50 AM
    I am new to Aruba controller configurations. Could someone please assist me to configure a scenario with 2 ISP's. I would like to map these 2 connections to 2 separate SSID's. I understand that it is possible through Policy Based Routing but now really sure how the config should be done. Both ISP's can be direclty connected to the WLC or can have a trunk link carrying these two ISP's in two VLAN's.
    Thanks in adavcne.
  • 2.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 10:01 AM
    What version of AOS code are you running ? And what controller ?
  • 3.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 10:10 AM
    Thanks for responding. Here are the information
    ArubaOS (MODEL: Aruba7030), Version 6.4.3.6
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    Compiled on 2015-12-11 at 17:31:07 PST (build 52927) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.2.0 (build 46859)
    Built: 2014-10-31 10:14:12
    Built by: p4build@re_client_46859
    Switch uptime is 2 hours 9 minutes 1 seconds
    Reboot Cause: User reboot (Intent:cause:register 78:86:50:60)
    Supervisor Card
    Processor (XLP208 Rev B0 (Secure Boot) , 1600 MHz) with 3736M bytes of memory.
    32K bytes of non-volatile configuration memory.
    3872M bytes of Supervisor Card system flash.
  • 4.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 12:12 PM
    For each vlan just make the clients default gateway to be the respective ISP router.
  • 5.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 12:20 PM
    Thanks Michael. Right now i am using internal DHCP server of the WLC for the guest SSID's. The 2 ISP connections are connected to the WLC through a trunk port and i have created IP interfaces for them. I am not sure by adding those ISP routers as default gateways to SSID can help me. Please advice.
  • 6.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 12:24 PM
    You would change that in the dhcp configuration for those respective subnets.
    ip dhcp pool <name>
    default-router <gateway-ip>
  • 7.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 12:46 PM
    Let me try this. So do i have to add two default routes in to the controllers routing table as well?
  • 8.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 01:18 PM
    Tried and i am afraid its not a successful one.
  • 9.  RE: 2 SSID's & 2 ISP's
    Posted Feb 22, 2016 02:46 PM
    Ishan,
    What's not working exactly?  Do the clients get an ip address?  Can they ping the default gateway, or at least see an arp entry for it?
    Are you able to share the config for the controller?
  • 10.  RE: 2 SSID's & 2 ISP's
    Posted Jan 13, 2019 05:54 AM
    your configuration should do from both  controller and switch.
    Controller configuration
    use /(split tunel mode)
    SSID 1 = VLAN 2 , default gateway ISP1 router IP(if local DHCP scope)
    SSID 2 = VLAN 3 , default gateway ISP2 router IP(if local DHCP scope)
    APs should
    Switch Configuration
    tag vlan 2 - switch port which connect ISP 1
    tag vlan 3 - switch port  which connect ISP 2
    use ISP router mange DHCP or same range DHCP scope for each user VLANs
