200 units S2500 switch tunnel node to 7240 Controller
  • 1.  200 units S2500 switch tunnel node to 7240 Controller
    Posted Jan 21, 2014 10:45 PM
    Does anyone ever deploy 200 units S2500 switch tunnel node to 1 unit of 7240 controller? The 7240 controller use SFP+ 10GB as a backbone connectivity.
    200 units S2500 switch will located at different building within campus.
    Is there have any performance issue?
    #7240
  • 2.  RE: 200 units S2500 switch tunnel node to 7240 Controller
    Posted Jan 22, 2014 04:41 PM
    Hope this helps:
    2014-01-22 16_39_44-www.arubanetworks.com_pdf_products_matrix-mobility-controller.pdf.png
    Also you should open a ticket with TAC to make sure you have the right AOS code for the switches and controller to support what you are trying to do
    #7240
  • 3.  RE: 200 units S2500 switch tunnel node to 7240 Controller
    Posted Jan 23, 2014 07:36 PM
    Keep in mind that much of the functionality with tunneled-node can be replicated on the switch itself without tunneled-node (local packet processing).
    #7240
