Wired Intelligent Edge
2626 J4900b Reset no response
  • 1.  2626 J4900b Reset no response
    Posted May 31, 2014 03:15 AM
    Hi all,
    I've just reset my Procurve 2626 J4900b and now I can't get anything out of it?
    It reboots fine, and the lights indicate it's going through it's POST cycle, but after that, I've got no management interfaces?
    I held down the RESET + CLEAR buttons as per the manual and then released the CLEAR as the Self Test started blinking. That caused it to do the reset and POST... but now I can't get any management info out of it?
    I've tried connecting to the Console, nothing?!
    I've tested that cable on another switch and it's fine.
    9600, 8 data, 1 stop, no parity, Xon/Xoff
    I've looked in the manual and even tried the Upload firmware steps if corruption is suspected. (no flow control)
    I can't work out what is going on?
    Would the Management Web interface be up?
    If so, what is the default IP address of the switch post config reset?
    #J4900b
    #Default
    #clear
    #2626
    #reset
    #firmware
