Hi, when i shutdown the switch to change, when i turned it on the configurations are away no vlans, no ip nothing (factory default) i had to config the switch for a second time,
i have to change the place of 6 switches, is'nt there any way to make the switch to save its configuration?
best regards
Tony
#2910al
