Wired Intelligent Edge
4SFP+ MAC sec module
  • 1.  4SFP+ MAC sec module
    Posted Jan 25, 2019 01:27 AM
    Hi guys,
    I need to know the use of the MAC sec module on 3810 switch series. Is it used for stacking, uplink or just simply SFP+ connection
  • 2.  RE: 4SFP+ MAC sec module
    MVP EXPERT
    Posted Jan 25, 2019 01:38 AM
    The 3810M require stacking link modules with stacking cables. The macsec module are simple sfp+ connections with macsec capability.
    Stacking Modules
    System (std 0 // max=1) User Selection (min 0 / max=1) per Chassis Aruba 3810M 4-port Stacking Module
    • min=1 \ max=4 Stacking cables Configuration Rules:
    JL084A See Configuration NOTE: 1
    J9578A J9665A J9579A
    NOTE 1
    Uplink Modules
    One of the following Stacking Cables must be selected:
    Aruba 3800/3810M 0.5m Stacking Cable Aruba 3800/3810M 1m Stacking Cable Aruba 3800/3810M 3m Stacking Cable
  • 3.  RE: 4SFP+ MAC sec module
    Posted Jan 25, 2019 03:01 AM
    Hey!!
    Thanks for the info.
    Just to confirm, we can do uplinks on mac sec modules?
  • 4.  RE: 4SFP+ MAC sec module
    MVP EXPERT
    Posted Jan 25, 2019 03:59 AM
    Yes its also a ‘normal’ sfp+ 10gb uplink
  • 5.  RE: 4SFP+ MAC sec module
    Posted Jan 25, 2019 10:44 AM
    Thanks!
  • 6.  RE: 4SFP+ MAC sec module
    Posted Nov 15, 2019 04:24 PM
    Just to double-check a piece of information,
    Is it ok to have an uplink between Macsec module (let s say 3810M -4SFP+ mac sec to a normal module (i.e:5406- 8p 1G/10GbE SFP+ v3)
    Another question, how the Macsec works? if we have 2 connected macsec module they will auto-negotiate L2 data encryption?
