50ohm Terminators Question
  • 1.  50ohm Terminators Question
    Posted Nov 19, 2021 07:04 PM
    Afternoon everyone,
    I am looking to deploy 11 AP-518's for a customer. While we've done a number of outside AP deployments with internal antenna's. This is our first project using external antenna. In reading the details for the ANT-3x3-5712 5Ghz 11.5dBi antenna, I see that 50ohm terminator is required.
    Fine, however I seem to be google search challenged in finding a 50ohm RPSMA male terminator rated for 5Ghz (I have since found that some terminators are rated for up to 6Ghz). I can find 50ohm RPSMA  for 2.4Ghz easy enough.
    Can someone post a link on where I can source the correct terminator (US source pls).
    Here is a RPSMA 50ohm male, however I can't tell what the Ghz rating is.
    Amphenol RF 132360RP
    Alliedelec remove preview
    132360RP from Amphenol RF at Allied Electronics & Automation
    View this on Alliedelec >
    This looks like exactly what I need, however I'd prefer to source it state side.
    50 Ohm Coaxial Terminator / Resistor - RP-SMA male (wifi-shop24.com)
    Thanks.
    -Tim Mann
    Tim Mann
  • 2.  RE: 50ohm Terminators Question
    Posted Nov 19, 2021 07:58 PM
    Tim,
    Here you go from https://l-com.com:
    Brad
    Brad
  • 3.  RE: 50ohm Terminators Question
    Posted Nov 19, 2021 08:06 PM
    Brad,
    Thanks! I don't know why I was alerted to Onno's response and not yours, but much appreciated!
    Cheers,
    -Tim
    Tim Mann
  • 4.  RE: 50ohm Terminators Question
    Posted Nov 19, 2021 07:59 PM
    That Amphenol terminator should be fine. Most terminators support frequencies from DC to 50GHz, so any reputable 50 ohm RP-SMA terminator will do.
    Pasternack is another great source for stuff like this.
    Onno Harms
  • 5.  RE: 50ohm Terminators Question
    Posted Nov 19, 2021 08:05 PM
    Thanks Onno for the prompt reply.
    I had check out Pasternack, but I left like I was going in circles there.
    This one small item was holding things up. lol.
    Cheers,
    -Tim
    Tim Mann
