we want to update the firmware on our 5308xl switches. Currently running E.10.74. The only version available to download is K.15.04. Is this right?
The release notes say there is a bootRom update required. It also says
"If your switch is running a software version earlier than
K.15, your BootROM will be updated when you upload
K.15.04.xxxx software to your switch. "
Does this mean the bootRom will be updated automatically when I load the new version? Am I right to go from E.10 to K.15?
#firmwareupdate
