Comware
5510 HI - Logs error- (LACP)
  • 1.  5510 HI - Logs error- (LACP)
    Posted Jul 04, 2024 07:54 AM
    Can you help me between different error view in logs ?
    The links in the aggregate fall at the same time and take two minutes to return. All LACPs are affected, but at different times.
    Best regards
    The LACP is configured as :
    interface Bridge-Aggregation4
    description INF60-07
    port link-type trunk
    undo port trunk permit vlan 1
    port trunk permit vlan 2 to 7 9 to 10
    link-aggregation mode dynamic
    mad enable
    interface Bridge-Aggregation26
    description INF60-12
    mad enable
    Error Logs
    %Jul 3 02:34:56:734 2024 INF60-01 LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/4 of aggregation group BAGG4 changed to the inactive state, because the physical state of the port is down.
    %Jul 3 02:34:55:861 2024 INF60-01 LLDP/6/LLDP_DELETE_NEIGHBOR: -Slot=2; Nearest bridge agent neighbor deleted on port GigabitEthernet2/0/4 (IfIndex 67), neighbor's chassis ID is dc68-0c12-7bc0, port ID is Ten-GigabitEthernet2/0/25.
    %Jul 3 02:34:56:757 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/4 changed to down.
    %Jul 3 02:34:56:824 2024 INF60-01 LAGG/6/LAGG_INACTIVE_PARTNER: Member port GE2/0/4 of aggregation group BAGG4 changed to the inactive state, because the aggregation configuration of its peer port is incorrect.
    %Jul 3 02:34:56:851 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/4 changed to down.
    %Jul 3 02:34:56:868 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation4 changed to down.
    %Jul 3 02:34:56:872 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation4 changed to down.
    %Jul 3 02:34:57:028 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/4 changed to down.
    %Jul 3 02:34:57:135 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/4 changed to down.
    %Jul 3 02:34:57:914 2024 INF60-01 LAGG/4/LACP_MAD_INTERFACE_CHANGE_STATE: LACP MAD function enabled on Bridge-Aggregation4 changed to the faulty state.
    %Jul 3 02:35:27:572 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/4 changed to up.
    %Jul 3 02:35:27:622 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port GE1/0/4 of aggregation group BAGG4 changed to the active state.
    %Jul 3 02:35:27:660 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation4 changed to up.
    %Jul 3 02:35:27:661 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation4 changed to up.
    %Jul 3 02:35:27:666 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/4 changed to up.
    %Jul 3 02:35:27:784 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/4 changed to up.
    %Jul 3 02:35:27:866 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port GE2/0/4 of aggregation group BAGG4 changed to the active state.
    %Jul 3 02:35:27:891 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/4 changed to up.
    %Jul 3 02:50:31:691 2024 INF60-01 LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE1/0/3 of aggregation group BAGG3 changed to the inactive state, because the physical state of the port is down.
    %Jul 3 02:50:30:867 2024 INF60-01 LLDP/6/LLDP_DELETE_NEIGHBOR: -Slot=2; Nearest bridge agent neighbor deleted on port GigabitEthernet2/0/3 (IfIndex 66), neighbor's chassis ID is 4cae-a359-22b4, port ID is Ten-GigabitEthernet1/0/50.
    %Jul 3 02:50:31:769 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/3 changed to down.
    %Jul 3 02:50:31:785 2024 INF60-01 LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port GE2/0/3 of aggregation group BAGG3 changed to the inactive state, because the physical state of the port is down.
    %Jul 3 02:50:31:800 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/3 changed to down.
    %Jul 3 02:50:31:805 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/3 changed to down.
    %Jul 3 02:50:31:834 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation3 changed to down.
    %Jul 3 02:50:31:835 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation3 changed to down.
    %Jul 3 02:50:31:915 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/3 changed to down.
    %Jul 3 02:50:32:217 2024 INF60-01 LAGG/4/LACP_MAD_INTERFACE_CHANGE_STATE: LACP MAD function enabled on Bridge-Aggregation3 changed to the faulty state.
    %Jul 3 02:51:02:375 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port GE1/0/3 of aggregation group BAGG3 changed to the active state.
    %Jul 3 02:51:02:456 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet1/0/3 changed to up.
    %Jul 3 02:51:02:456 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation3 changed to up.
    %Jul 3 02:51:02:457 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation3 changed to up.
    %Jul 3 02:51:02:460 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet1/0/3 changed to up.
    %Jul 3 02:51:02:652 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface GigabitEthernet2/0/3 changed to up.
    %Jul 3 02:51:02:673 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port GE2/0/3 of aggregation group BAGG3 changed to the active state.
    %Jul 3 02:51:02:701 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface GigabitEthernet2/0/3 changed to up.
    %Jul 3 02:51:03:639 2024 INF60-01 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port GigabitEthernet1/0/3 (IfIndex 3), neighbor's chassis ID is 4cae-a359-22b4, port ID is Ten-GigabitEthernet1/0/49.
    %Jul 3 02:51:02:745 2024 INF60-01 LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=2; Nearest bridge agent neighbor created on port GigabitEthernet2/0/3 (IfIndex 66), neighbor's chassis ID is 4cae-a359-22b4, port ID is Ten-GigabitEthernet1/0/50.
    %Jul 3 02:51:04:427 2024 INF60-01 STP/6/STP_DETECTED_TC: Instance 0's port Bridge-Aggregation3 detected a topology change.
    %Jul 3 02:51:07:237 2024 INF60-01 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation3 was notified a topology change.
    %Jul 3 02:51:37:913 2024 INF60-01 LAGG/5/LACP_MAD_INTERFACE_CHANGE_STATE: LACP MAD function enabled on Bridge-Aggregation3 changed to the normal state.
    %Jul 3 12:03:27:640 2024 INF60-01 LPDT/4/LPDT_LOOPED: Loopback exists on Bridge-Aggregation26.
    %Jul 3 12:03:27:694 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/26 changed to down.
    %Jul 3 12:03:27:695 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/26 changed to down.
    %Jul 3 12:03:27:700 2024 INF60-01 LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port XGE1/0/26 of aggregation group BAGG26 changed to the inactive state, because the physical state of the port is down.
    %Jul 3 12:03:27:700 2024 INF60-01 LAGG/6/LAGG_INACTIVE_CONFIGURATION: Member port XGE2/0/26 of aggregation group BAGG26 changed to the inactive state, because the aggregation configuration of the port is incorrect.
    %Jul 3 12:03:27:879 2024 INF60-01 LPDT/4/LPDT_VLAN_LOOPED: Loopback exists on Bridge-Aggregation26 in VLAN 9.
    %Jul 3 12:03:27:897 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/26 changed to down.
    %Jul 3 12:03:27:898 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/26 changed to down.
    %Jul 3 12:03:27:912 2024 INF60-01 LPDT/5/LPDT_VLAN_RECOVERED: Loopback on Bridge-Aggregation26 in VLAN 9 recovered.
    %Jul 3 12:03:27:915 2024 INF60-01 LAGG/4/LACP_MAD_INTERFACE_CHANGE_STATE: LACP MAD function enabled on Bridge-Aggregation26 changed to the faulty state.
    %Jul 3 12:03:27:912 2024 INF60-01 LPDT/5/LPDT_RECOVERED: Loopback on Bridge-Aggregation26 recovered.
    %Jul 3 12:03:27:942 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation26 changed to down.
    %Jul 3 12:03:27:943 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation26 changed to down.
    %Jul 3 12:03:58:757 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/26 changed to up.
    %Jul 3 12:03:58:803 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port XGE1/0/26 of aggregation group BAGG26 changed to the active state.
    %Jul 3 12:03:58:859 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation26 changed to up.
    %Jul 3 12:03:58:860 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation26 changed to up.
    %Jul 3 12:03:58:862 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/26 changed to up.
    %Jul 3 12:03:58:951 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/26 changed to up.
    %Jul 3 12:03:59:072 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port XGE2/0/26 of aggregation group BAGG26 changed to the active state.
    %Jul 3 12:03:59:095 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/26 changed to up.
    %Jul 3 12:04:00:282 2024 INF60-01 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/26 (IfIndex 26), neighbor's chassis ID is ec9b-8b90-faa0, port ID is Ten-GigabitEthernet1/0/49.
    %Jul 3 12:03:59:607 2024 INF60-01 LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=2; Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/0/26 (IfIndex 89), neighbor's chassis ID is ec9b-8b90-faa0, port ID is Ten-GigabitEthernet3/0/49.
    %Jul 3 12:04:01:446 2024 INF60-01 STP/6/STP_DETECTED_TC: Instance 0's port Bridge-Aggregation26 detected a topology change.
    %Jul 3 12:04:03:746 2024 INF60-01 STP/6/STP_NOTIFIED_TC: Instance 0's port Bridge-Aggregation26 was notified a topology change.
    %Jul 3 12:04:07:913 2024 INF60-01 LAGG/5/LACP_MAD_INTERFACE_CHANGE_STATE: LACP MAD function enabled on Bridge-Aggregation26 changed to the normal state.
    %Jul 3 12:07:57:740 2024 INF60-01 LPDT/4/LPDT_LOOPED: Loopback exists on Bridge-Aggregation26.
    %Jul 3 12:07:57:982 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/26 changed to down.
    %Jul 3 12:07:57:984 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/26 changed to down.
    %Jul 3 12:07:57:986 2024 INF60-01 LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port XGE1/0/26 of aggregation group BAGG26 changed to the inactive state, because the physical state of the port is down.
    %Jul 3 12:07:57:987 2024 INF60-01 LAGG/6/LAGG_INACTIVE_CONFIGURATION: Member port XGE2/0/26 of aggregation group BAGG26 changed to the inactive state, because the aggregation configuration of the port is incorrect.
    %Jul 3 12:07:58:049 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation26 changed to down.
    %Jul 3 12:07:58:049 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation26 changed to down.
    %Jul 3 12:07:58:054 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/26 changed to down.
    %Jul 3 12:07:58:074 2024 INF60-01 LPDT/4/LPDT_VLAN_LOOPED: Loopback exists on Bridge-Aggregation26 in VLAN 9.
    %Jul 3 12:07:58:075 2024 INF60-01 LPDT/5/LPDT_VLAN_RECOVERED: Loopback on Bridge-Aggregation26 in VLAN 9 recovered.
    %Jul 3 12:07:58:076 2024 INF60-01 LPDT/5/LPDT_RECOVERED: Loopback on Bridge-Aggregation26 recovered.
    %Jul 3 12:07:58:111 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/26 changed to down.
    %Jul 3 12:08:02:217 2024 INF60-01 LAGG/4/LACP_MAD_INTERFACE_CHANGE_STATE: LACP MAD function enabled on Bridge-Aggregation26 changed to the faulty state.
    %Jul 3 12:08:28:716 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet1/0/26 changed to up.
    %Jul 3 12:08:28:716 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Ten-GigabitEthernet2/0/26 changed to up.
    %Jul 3 12:08:28:810 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port XGE1/0/26 of aggregation group BAGG26 changed to the active state.
    %Jul 3 12:08:28:901 2024 INF60-01 LAGG/6/LAGG_ACTIVE: Member port XGE2/0/26 of aggregation group BAGG26 changed to the active state.
    %Jul 3 12:08:28:993 2024 INF60-01 IFNET/3/PHY_UPDOWN: Physical state on the interface Bridge-Aggregation26 changed to up.
    %Jul 3 12:08:28:995 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Bridge-Aggregation26 changed to up.
    %Jul 3 12:08:28:998 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet1/0/26 changed to up.
    %Jul 3 12:08:29:000 2024 INF60-01 IFNET/5/LINK_UPDOWN: Line protocol state on the interface Ten-GigabitEthernet2/0/26 changed to up.
    %Jul 3 12:08:29:006 2024 INF60-01 STP/6/STP_DETECTED_TC: Instance 0's port Bridge-Aggregation26 detected a topology change.
    %Jul 3 12:08:30:282 2024 INF60-01 LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent neighbor created on port Ten-GigabitEthernet1/0/26 (IfIndex 26), neighbor's chassis ID is ec9b-8b90-faa0, port ID is Ten-GigabitEthernet1/0/49.
    %Jul 3 12:08:29:678 2024 INF60-01 LLDP/6/LLDP_CREATE_NEIGHBOR: -Slot=2; Nearest bridge agent neighbor created on port Ten-GigabitEthernet2/0/26 (IfIndex 89), neighbor's chassis ID is ec9b-8b90-faa0, port ID is Ten-GigabitEthernet3/0/49.
