Thanks for reply, would is it possible to extend number of interface where VRRP can operate using master and subordinate groups? For example I am trying this configuration:
GW1
vrrp send-gratuitous-arp
interface Vlan-interface300
description GROUP1 Transit
ip binding vpn-instance G1
ip address 192.168.0.2 255.255.255.0
vrrp vrid 3 virtual-ip 192.168.0.2
vrrp vrid 3 preempt-mode delay 5
vrrp vrid 3 name GROUP1
interface Vlan-interface301
description GROUP1 Endpoints
ip address 192.168.1.2 255.255.255.0
vrrp vrid 3 virtual-ip 192.168.1.1
vrrp vrid 3 follow GROUP1
The GW2 is configured similarly, except real IP is .3 and priority is 90. The state from Master point of view looks healthy.
IPv4 Virtual Router Information:
Running mode : Standard
Gratuitous ARP sending interval : 120 sec
Total number of virtual routers : 2
Interface Vlan-interface300
VRID : 3 Adver Timer : 100
Admin Status : Up State : Master
Config Pri : 100 Running Pri : 100
Preempt Mode : Yes Delay Time : 5
Auth Type : MD5 Key : ******
Virtual IP : 192.168.0.1
Virtual MAC : 0000-5e00-0103
Master IP : 192.168.0.2
Config Role : Master
Interface Vlan-interface301
Auth Type : None
Virtual IP : 192.168.1.1
Master IP : 192.168.1.2
Config Role : Subordinate
Follow Name : GROUP1
But only Master GW can reach VIP for Subordinate group, downstream switch or Backup GW cannot reach it via ICMP, even they have resolved it on Layer 2.
<Access>disp arp
Type: S-Static D-Dynamic O-Openflow R-Rule M-Multiport I-Invalid
IP address MAC address VLAN Interface Aging Type
192.168.1.1 0000-5e00-0103 301 XGE1/0/51 19 D
192.168.1.2 ec9b-8b62-45ba 301 XGE1/0/51 19 D
192.168.1.3 ec9b-8b62-411b 301 XGE1/0/51 19 D
<Access>ping 192.168.1.1
Ping 192.168.1.1 (192.168.1.1): 56 data bytes, press CTRL_C to break
Request time out
Request time out
Request time out
Request time out
GW1 and GW1 real address are rechable from this access switch.
Firmware is 7.10_R2612P02.
Edit: I have re-tested this feature again using 7.10_R2612P01 and it resovled the issues with reachabilitu, looks like code issue in latest GA release.
