6000 Controller CPU
  • 1.  6000 Controller CPU
    Posted Jun 11, 2014 11:11 AM
    Before I open up a TAC case, is there a known issue with the 6000 controller's high CPU running AOS 3.4.5.1 ?
  • 2.  RE: 6000 Controller CPU
    Posted Jun 11, 2014 11:54 AM
    Can you define what is "high" for you?  How many APs are terminating on the controller?
    Also, is this an M3 or a Sup-2?   Are you by chance using a 2048-bit certificate on the box (Captive Portal)?   If so, see Colin's post here:  http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Aruba6000-Version-3-4-5-1-Switched-form-1024-to-2048-bit-cert/m-p/86138/highlight/true#M15296
  • 3.  RE: 6000 Controller CPU
    Posted Jun 11, 2014 12:31 PM
    We're using the M3's terminating 395 APs. I noticed that the CPU fluctuates between mid-90s and mid-30s (what I mean by this is when I do a show cpuload the “user” percentage is very high leaving the “idle” very low with the system between 1.4 - 1.9). Also, what is the "user" on the controller referring to when I do a show cpuload? Is it user traffic or the user logged into the controller?
  • 4.  RE: 6000 Controller CPU
    Posted Jun 11, 2014 02:58 PM
    user = % of controller CPU resources used by application processes
    system = % of controller CPU resources used by system processes
    idle = % of unused controller CPU resources
    The following is taken from the Mobility Controller VRD.  If you want to have a detailed analysis done, pursue your TAC case and see what they have to say specific to your version, etc.
    The organization should consider the CPU to be highly utilized at 70% (begin monitoring regularly) and considered critical at 100% (being investigating) over a 5-minute period. Alternatively, consider using AirWave to track average CPU utilization over time.  If the CPU utilization is sustained or regularly spikes above these thresholds, consider an upgrade  to add capacity to the system
  • 5.  RE: 6000 Controller CPU
    Posted Jun 16, 2014 10:48 AM
    hi cdj
    3.4.x is end of support, you may have a hard time getting some love, if so, please paste here
    show cpuload current
    show processes sort-by cpu
    show datapath utilization
    do you have captive portal by any chance ?
    regards
    -jeff
