6.11.3 - ClearPass - File System Integrity Check - Failure
This thread has been viewed 22 times
  • 1.  6.11.3 - ClearPass - File System Integrity Check - Failure
    Posted Dec 05, 2023 10:42 AM
    Hi all,
    I just noticed this error is happening every day. I cannot find relevant information.  Is this something to be concern about or need upgrade to latest?
    ClearPass Version  6.11.3.253363
    Source: File System Integrity Check
    Level: WARN
    Category: Filesystem Integrity Check
    Action: Failure
    Timestamp    Dec 04, 2023 03:31:30 UTC
    Description
    DBG: md_enable: algorithm 0 not available
    WARNING: file:/var/lib/aide/aide.db.gz: gcry_md_enable (gost) failed for 'file:/var/lib/aide/aide.db.gz'
    WARNING: file:/var/lib/aide/aide.db.gz: gcry_md_enable (stribog256) failed for 'file:/var/lib/aide/aide.db.gz'
    WARNING: file:/var/lib/aide/aide.db.gz: gcry_md_enable (stribog512) failed for 'file:/var/lib/aide/aide.db.gz'
    I found another similar issue 3 years ago 6.9.2 - File System Integrity Check (ERROR) | Security (arubanetworks.com) bug id is CP‑37640, but it fixed in 6.9.8 Policy Manager (arubanetworks.com).
    It still happening on the later version device.
  • 2.  RE: 6.11.3 - ClearPass - File System Integrity Check - Failure
    Posted Dec 05, 2023 05:48 PM
    i have not seen this on CP6.11.6 that i am running.
    anyway it is best to run the latest maintenance release. Here is the consolidated release notes for 11.6.x
  • 3.  RE: 6.11.3 - ClearPass - File System Integrity Check - Failure
    Posted Dec 05, 2023 06:06 PM
    Hi Ariyap,
    Thank you for your help. We have two ClearPass are running 6.11.3.253363. One is no error, another is failure. So, I'm not sure what is reason.
    This log is from few months ago and happed every day.
  • 4.  RE: 6.11.3 - ClearPass - File System Integrity Check - Failure
    Posted Jun 04, 2024 04:25 AM
    hello guys,
    is there any update on this issue? I am running 4 nodes in total on 6.11.7, two of them show the File System Integrity Check: WARNING: file:/var/lib/aide/aide.db.gz
    This happened a few weeks after adding the affected nodes to the new cluster after the 6.11 upgrade.
    Cheers
  • 5.  RE: 6.11.3 - ClearPass - File System Integrity Check - Failure
    Posted Jun 04, 2024 09:26 AM
    There seems to be a bug for this (CP-50540) applicable to version 6.11.7; and the message can be safely ignored. You may reach out to TAC to verify this is the issue/case.
  • 6.  RE: 6.11.3 - ClearPass - File System Integrity Check - Failure
    Posted Jun 04, 2024 10:03 AM
    Thank you Herman! Update to 6.11.8 is already on the list.
