What happens if you "write erase all", add the license for POE back to the controller and connect an access point on ports 0 to 3 and the AP does not power up.
Also if you navigate to controller -> licenses nothing shows up but if you type "show license", you see active licenses.
Any ideas?
To Note:
SInce this is a test controller, I have added the permanent POE license as well as some EVAL AP, PEFNG and RF Protect licenses.
