6.3.1 RAP database msg...
  • 1.  6.3.1 RAP database msg...
    Posted Oct 28, 2013 05:29 AM
    Hi all,
    After upgrading to 6.3.1, you of course get the following on the CLI (when logging in)...
    "WARNING: This controller has RAP whitelist data stored in pre-6.3 format..."
    After commiting the "local-userdb-ap del all" command however, this message persists in the CLI.
    Anybody else seeing this?
  • 2.  RE: 6.3.1 RAP database msg...
    Posted Oct 28, 2013 07:58 AM
    I am seeing it as well.
    I ran "local-userdb-ap del all" and it removed all the entries in that database.
    I then saved the config, message was still there.
    I removed all of my APs using the whitelist-db del command and re-added them with the whitelist-db add command
    message still there.
    I exported the gap-db, same thing.
  • 3.  RE: 6.3.1 RAP database msg...
    Posted Oct 28, 2013 08:12 AM
    try whitelist-db rap purge and then do a show whitelist-db rap to see if it is there.
    If you login and you can still see the message you may have to reboot the controller.
  • 4.  RE: 6.3.1 RAP database msg...
    Posted Oct 28, 2013 08:34 AM
    no need to do the purge. Good thought though.
    Just tested on another controller.
    Simply run "local-userdb-ap del all" and reboot the controller and the message disappears.
  • 5.  RE: 6.3.1 RAP database msg...
    Posted Oct 28, 2013 08:57 AM
    Ahh, reboot fix yes? Cool. Thanks all.
  • 6.  RE: 6.3.1 RAP database msg...
    Posted Oct 28, 2013 09:09 AM
    reboot and it disappears.
  • 7.  RE: 6.3.1 RAP database msg...
    Posted Nov 03, 2013 12:58 PM
    Did you run into any issue where your RAPs no longer came back online?
    I'm having an issue with my RAP-2WG APs. After upgrading to 6.3.1.1, they wouldn't come back online.
  • 8.  RE: 6.3.1 RAP database msg...
    Posted Nov 04, 2013 08:15 AM
    I did see this during an upgrade to 6.3.1.0 where some RAPs didn't come back.
    The customer logged a TAC case and was told that it was due to bug 88314 which was fixed in 6.3.1.1.
    As you upgraded to 6.3.1.1, that can't be the same thing.
    I recommend you log it with TAC if not done so already!
  • 9.  RE: 6.3.1 RAP database msg...
    Posted Nov 04, 2013 03:20 PM
    Thanks.
    I have a Ticket with TAC already although he seemed clueless.
    Will see what happens.
  • 10.  RE: 6.3.1 RAP database msg...
    Posted Nov 04, 2013 04:07 PM
    Thanks.
    eosuorah,
    At any point, you can ask to have your case escalated if you feel like you are getting nowhere.
