6.3.1.1 - L2 GRE terminating on master-vrrp
  • 1.  6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 20, 2014 11:20 AM
    I have a customer on 6.3.1.1 where some of the local controllers have a L2 GRE tunnel setup for the guest traffic, that goes through to the master controller.
    The setup was typical with the below, and explained in many threads in these forums.
    Local
    Tunnel source - vlan ip
    Tunnel destination - master vrrp
    Master
    Tunnel destination - local controller vlan ip
    Unfortunately there were many issues with the guest network stopping working from time to time. TAC have said to the customer that this setup is wrong and you cannot set the tunnel destination to be the vrrp address.
    I know this is supported since 3.x, so why is TAC saying that it is wrong?  There are so many other examples in here of people doing exactly that above and it works fine on other versions.  Nothing in the UG or release notes says that this is unsupported either.
    They have also suggested setting up a tunnel to the master-backup as well, in case of failover, which makes no sense to me since there will be two active tunnels for the same vlan.
    rant over.
    :smileywink:
  • 2.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 20, 2014 11:51 AM
    We've got quite a few large (65K+ guest) deployments running with a similar challenge, and we've had to utilize GRE tunnel groups to accomplish this feat, (as VRRP cannot be GRE endpoint).    In fact, I believe this is the exact reason why GRE tunnel redundancy (GRE tunnel groups) were added to the AOS firmware in 6.3.x
      (The other option is GRE through an Load Balancer such as F5 LTM, with primary/failover endpoint definition to avoid scattering data).
  • 3.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 20, 2014 11:58 AM
    This has been an issue for as long as I'm aware:
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/VRRP-IP-cannot-be-L2-GRE-tunnel-endpoint/td-p/33572
    The issue is related to heartbeats that will only be sourced from the physical address, not from VRRP address, thus need to tunnel endpoints to be physical IP addresses.
    This is not an Aruba only issue, it's related to the VRRP specifications.   JunOS / Vyatta / and others have same restrictions.   Use of the GRE tunnel groups overcomes the limitations, and the "control" can be from the GRE Tunnel initiator.
    So if you have an internal controller doing GRE to a pair of DMZ/Guest controllers, the control of tunnel priority is on the inside, vs the outside if relying on VRRP.
  • 4.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 20, 2014 05:43 PM
    This is the way this works:
    Local
    Master
    Tunnel source - VRRP IP
  • 5.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 21, 2014 03:29 AM
    Ok, TAC are saying that you can't use the vrrp that is used for master-redundancy, but rather need to use a different one that is on another vlan.
    Tunnel-groups does sound interesting, but that seems to only be for L3 tunnels.
    Local
    Master
    Unfortunately, I'm getting conflicting ideas how to do this.  Like what you've said here, http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/VRRP-IP-cannot-be-L2-GRE-tunnel-endpoint/m-p/33799/highlight/true#M8323
    and here also is what someone else did to get it working, http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Terminating-GRE-tunnels-on-VRRP/m-p/40126/highlight/true#M9238
    For now, it terminates on the vlan ip and hence no failover capability.
  • 6.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 25, 2014 08:10 PM
    Hi Michael,
    I would be keen to hear how you go with this. I am facing a design scenario where there will be a Active/Passive Master pair (that also terminate APs) and a DMZ controller acting as a Guest anchor.
    Therefore my L2GRE tunnel would idealy be sourced from a VRRP address on the master pair, and terminated on the physcial address on the DMZ controller.
    Chris
  • 7.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 21, 2014 07:26 AM
    Michael_Clarke,
    It only works if it works for you. You at least have multiple avenues to try. The behavior has changed over time. What I posted in this thread was the last thing I did to get it to work. Please let us know what works for you.
  • 8.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Feb 24, 2014 05:04 AM
    That's unfortunate.  I can't have a feature setup that works for one customer, but doesn't for the next, or works one day, then breaks the next after an upgrade.
    Nevertheless, if we manage to get it sorted, I will post back what we did.
    :smileyhappy:
  • 9.  RE: 6.3.1.1 - L2 GRE terminating on master-vrrp
    Posted Mar 26, 2014 06:22 AM
    @cjoseph wrote:
    Michael_Clarke,
    Had an Aruba SE with me looking at this with the customer.  We tested with a lab controller and got it to work with the following.
    New vrrp (same vlan as master-vrrp)
    Local Controller
    Interface tunnel x
    Tunnel source a.b.c.d
    Tunnel destination <vrrp-ip>
    Tunnel keepalive
    no inter-tunnel-flooding
    Master Controller
    Interface tunnel x
    Tunnel source <vrrp-ip>
    Tunnel destination a.b.c.d
    Tunnel keepalive
    No inter-tunnel-flooding
    We would prefer to have the vrrp on a different vlan from the master-vrrp (suggested by TAC), but that involves various other changes on the network so haven't tried that for now.
