6.3.1.15 master redudency not working :(
  • 1.  6.3.1.15 master redudency not working :(
    Posted Mar 01, 2015 11:40 AM
    Everytime we configure master redudency - connectiviy between both controller on same vlan/segment is gone...
    Disabling the VRRP master redudency making to ICMP to be back and work as needed.
    any advise?
    Standby:
    master-redundancy
      master-vrrp 100
      peer-ip-address 10.101.205.22 ipsec e5f06e6f176fec6396ec8c4f384fc904
    vrrp 100
      priority 110
      ip address 10.101.205.20
      vlan 205
      preempt delay 0
      tracking master-up-time 30 add 20
      no shutdown
    Master:
    master-redundancy
      master-vrrp 100
      peer-ip-address 10.101.205.21 ipsec aec369f929c79374d424ef9b301a552b
    vrrp 100
      priority 115
      vlan 205
      preempt delay 0
      no shutdown
    Please advise.
    Both controller can ICMP/ping each other on VLAN205...until i set the master redudency setting. :(
  • 2.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 01, 2015 12:06 PM
    What state is spanning-tree in when you enable VRRP?
    Tim
  • 3.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 01, 2015 12:08 PM
    Sapnning - tree is off on all interfaces/both controllers. y?
    The funny thing is that when master-redudency is enabled both controllers cannot icmp each other from same vlan/segment...but i can ping them from another computer on same VLAN .... both of them...
    when i disable the master redudency - both controllers again able to ping each other (both of them showing on each other ARP table)
  • 4.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 01, 2015 04:56 PM
    enable spanning tree for the vlan only. try that
  • 5.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 01:10 AM
    • On both controllers?
    • Even due that on the backbone switches both controllers are connected two STP is enabled?
    • Even due all othe vlans and even the vlan of the vrrp dont got any issue connecting from extranl pc on same vlan ? (until i enable the master redudency ?..and then the icmp/connecitivy between controllers on same vlan is lost)
  • 6.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 11:07 AM
    i had an issue with VRRP where the backup wouldn't becoy the master unless I enabled spanning tree for the vlan. it was enabled globally but wouldn't work. its a bug in the code that is fixed in a newer release
  • 7.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 11:18 AM
    Check the status of the IPSec tunnel between master and standby. if possible share the output of "show ip route" and "show switches"
    Please feel free for any further help on this.
  • 8.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 11:47 AM
    Please check this post
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/VRRP-Pinging-and-syncronisation-issue/m-p/219593
    in the past i got the same issue and it was because i was using nat inside the VRRP Master VLAN, the VRRP as you know use IPSEC , and ipsec does not support nat.
    Regards
  • 9.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 02:49 PM
    Thanks AirHeads.
    Problem solved by carefuly recondigured everything.
    (Thanks for the tip for not doing route-src-nat on any vlan you establishing the ipsec between the controllers in)
  • 10.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 02:56 PM
    where is my kudo  lol
  • 11.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 02:59 PM
    K+ you :) just because it's late.
    BUT FYI: srcnat wasn't configured on any vlan ip interface at all... the fix was a simple reconfigure ,looking good into details.(like ip/interfaces/vlan/vrrp id's) Solve the issue.
  • 12.  RE: 6.3.1.15 master redudency not working :(
    Posted Mar 02, 2015 11:48 AM
    Regards
