6.4 HW Supported
  • 1.  6.4 HW Supported
    Posted Jun 12, 2015 11:46 AM
    Hi to ALL!
    Do you have a list of Aruba Controller and AP supported on 6.4 release?
    And also can I have a multi-controller topology with a mixed 6.3 and 6.4 Controller?
    Thanks in advance
  • 2.  RE: 6.4 HW Supported
    Posted Jun 12, 2015 11:49 AM
    Take a look here:
    http://www.arubanetworks.com/support-services/end-of-life/#MobilityControllers
    You cannot have different major releases in a master-local topology.
    Tim
  • 3.  RE: 6.4 HW Supported
    Posted Jun 12, 2015 12:02 PM
    You can also refer to the AP Support section of the 6.4 release notes (Table 9 in the latest version):
    https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=17614
  • 4.  RE: 6.4 HW Supported
    Posted Jun 13, 2015 02:51 AM
    Hi Friend,
    Multi controller deployment, ( Master-Local) is a centralised config management model. Master controller is always used for Configuration, ARM and IDS where as Local controller is used for AP termination, processing user traffic and userrole assignment.
    Here master always push the config through PAPI and always in sync hence it is required to have same image version in both the controllers ( Master and Local).
    First of all it is not possible to bring up Master-local setup with different code, IPSec negotiation will be faild.
    Hope you got some more clarity on this.
    Please feel free for any further query on this.
  • 5.  RE: 6.4 HW Supported
    Posted Jun 15, 2015 04:53 AM
    Thanks to ALL for the quickly replies and support!
    I have checked RN and EOL documents and 6.4 is supported on 3200, 620 and 650 Controllers.
    I have only  a doubt regarding the AP105 (on documentations there is written TBD)....
    Someone can confirmed or not that AP105 support 6.4 ArubaOS?
  • 6.  RE: 6.4 HW Supported
    Posted Jun 15, 2015 05:34 AM
    AP-105 supports 6.4.
    Tim
