651 Wireless Side
  • 1.  651 Wireless Side
    Posted Mar 13, 2012 04:29 PM
    I have a651-us 6.1.2.4 & cannot seem to access the wireless side. I search for AP's on that device, but it does not recognize it. Is there some configuration entry necessary to "expose" the wireless side?
  • 2.  RE: 651 Wireless Side
    Posted Mar 13, 2012 06:20 PM
    Are you saying that you're not seeing the internal AP? Can you run 'show ap database long' from the CLI and let us know what you see?
    -awl
  • 3.  RE: 651 Wireless Side
    Posted Mar 14, 2012 10:42 AM
    (Aruba-wheelhouse) #show ap database long
    AP Database ----------- Name               Group   AP Type  IP Address    Status          Flags  Switch IP    Wired MAC Address  Serial #   Slot/Port  FQLN  Outer IP    User ----               -----   -------  ----------    ------          -----  ---------    -----------------  --------   ---------  ----  --------    ---- 00:0b:86:67:df:d9  cp-srv  RAP-5WN  192.168.0.20  Up 18h:11m:37s  Rc2    10.1.10.151  00:0b:86:67:df:d9  AG0024580  1/0        N/A   10.9.44.10
    Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed        I = Inactive; H = Using 802.11n license; D = Dirty or no config        X = Maintenance Mode; P = PPPoE AP; B = Built-in AP        R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP; c = CERT-based RAP; 2=Using IKE version 2        M = Mesh node; Y = Mesh Recovery
    Total APs:1
  • 4.  RE: 651 Wireless Side
    Posted Mar 14, 2012 10:47 AM
    Please send the output to "show log system all" to see if there is any issue initializing the internal AP.
  • 5.  RE: 651 Wireless Side
    Posted Mar 14, 2012 10:49 AM
    Colin beat me to it. I was also going to ask if you'd seen anything on the console when the controller was booting up.
    -awl
  • 6.  RE: 651 Wireless Side
    Posted Mar 14, 2012 11:00 AM
    attached is not a PDF but a txt file
    Attachment(s)
    pdf
    putty.pdf   22 KB 1 version
  • 7.  RE: 651 Wireless Side
    Posted Mar 14, 2012 12:48 PM
    The log in inconclusive.  Please open a suport case so they can determine what is going on.
  • 8.  RE: 651 Wireless Side
    Posted Jan 16, 2018 10:50 AM
    (Aruba650) #show ap database long AP Database ----------- Name Group AP Type IP Address Status Flags Switch IP Standby IP Wired MAC Address Serial # Port FQLN Outer IP User ---- ----- ------- ---------- ------ ----- --------- ---------- ----------------- -------- ---- ---- -------- ---- 00:0b:86:64:34:30 default 651 10.4.146.159 Down 10.4.146.159 0.0.0.0 00:0b:86:64:34:30 AF0001342 N/A N/A AP105 AP651 105 192.168.100.99 Up 18m:38s 2 192.168.100.22 0.0.0.0 24:de:c6:c3:c0:54 BT0522482 1/1 N/A N/A Flags: U = Unprovisioned; N = Duplicate name; G = No such group; L = Unlicensed I = Inactive; D = Dirty or no config; E = Regulatory Domain Mismatch X = Maintenance Mode; P = PPPoE AP; B = Built-in AP; s = LACP striping R = Remote AP; R- = Remote AP requires Auth; C = Cellular RAP; c = CERT-based RAP; 1 = 802.1x authenticated AP; 2 = Using IKE version 2 u = Custom-Cert RAP; S = Standby-mode AP; J = USB cert at AP i = Indoor; o = Outdoor M = Mesh node; Y = Mesh Recovery
