6.5.2 software and AP-220
  • 1.  6.5.2 software and AP-220
    Posted Aug 22, 2017 01:03 PM
    Hey all,
    Looking for a little clarification on the new software that allows you to configure AP's as IAP, RAP, CAP.  Can I upgrade my controller to 6.5.2 and convert an old controller based AP-205 or AP-225 to an IAP to make it controllerless based?  Or is this only available with newer AP models?  Any insight would be appreciated.
    Mike
  • 2.  RE: 6.5.2 software and AP-220
    Posted Aug 22, 2017 01:27 PM
    You cannot, any pre-UAP APs (currently anything NOT the 203/303, and 365), if it's an AP-XXX, it will ONLY do controller termination.
  • 3.  RE: 6.5.2 software and AP-220
    Posted Aug 22, 2017 01:47 PM
    Thank you
