6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
  • 1.  6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jun 21, 2018 12:06 PM
    This morning we upgraded two of our 5k clearpass boxes from 6.6.9 to 6.6.10.  When those boxes were rebooted, an error appeared in the event log: 'Failed to start cpass-domain-server_[institution name]'.  This was fixed by restarting the domain service.
    Since the update, all AD auths using MSCHAPv2 on those boxes results in a timeout.  The error appears in the access tracker:
    MSCHAP: AD status:{Device Timeout} The specified I/O operation on %hs was not completed before the time-out period expired. (0xc00000b5)
    MSCHAP: Authentication failed
    EAP-MSCHAPv2: User authentication failure
    The logs show a similar error, with the addition of this:
    ERROR RadiusServer.Radius - rlm_mschap: FAILED: MS-CHAP2-Response is incorrect
    The server that remains on 6.6.9 is unaffected by this behaviour, and the 6.6.10 servers can handle non-MSCHAPv2 authentications fine.
    The release notes for 6.6.10 show a few small changes in AD auth behaviour: release notes.  Could this explain the problem?
  • 2.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jun 21, 2018 12:27 PM
    What was the previous version you were on ?
    Sent from Mail for Windows 10
  • 3.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jun 21, 2018 12:30 PM
    6.6.9
  • 4.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jun 21, 2018 12:47 PM
    Always best to work with Aruba TAC for things like this.
  • 5.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jan 16, 2019 04:01 AM
    Does anyone have a fix on for this?
    After rebooting my machines (6.6.9) both of them show the same behaviour.
    Error messsage:
  • 6.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jan 16, 2019 04:23 AM
    Like Tim stated above I would work with TAC. There might be an underlying cause that we can’t troubleshoot here in the forum.
  • 7.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jan 16, 2019 04:34 AM
    Thanks for your answer. I just opened a TAC case!
  • 8.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jun 03, 2019 02:14 AM
    have you resolved.
  • 9.  RE: 6.6.10 upgrade seems to have caused timeouts for MSCHAPv2
    Posted Jun 03, 2019 02:22 AM
    This is an old thread. CPPM is currently on 6.8.x versions.6.6 is a very old version and if you are having issues with it then you need to call TAC.
