As it is end of support for 6.6.x
I have 6.6.9 cluster on windows hyper-v servers. I installed publisher/subscriber on 1TB virtual disks as the instructions indicate. I believe it was partitioned into two 500GB partitions when installed?
Will 6.7 install onto the inactive 500GB partition and leave the 6.6.9 on the other 500 GB partition in case of a need for rollback?
That is the bit that I am unclear on. The upgrade requirements seem to indicate a 1TB disk, so hoping that the disks I have are ready to go.
Thanks!
