I hope I chose the correct board.
I'm setting up an environment that has a 7010 controller that is acting as a VPN concentrator. A bunch of offices with IAPs connected back via VPN. The 7010 is the VPN concentrator. It also exports the learned the IPSec routes into OSPF (router ospf redistribute rapng-vpn).
We have 3 offices that it was decided to deploy 7005 controllers. What I'm wondering is if these controllers can connect to the VPN concentrator like an IAP?
From what I've read, if they are deployed as a branch office controller then yes. However, a branch office deployment requires the VPN concentrator to be a 7200 series. This is only a 7010.
I can setup a traditional IPSec configuration, create an OSPF stub area to handle these 3 locations but I"m trying to keep things simple.
Thanks in advance.
