7005 IAP-VPN
  • 1.  7005 IAP-VPN
    Posted Oct 11, 2017 08:25 PM
    How many Instant access points would be able to connect to a 7005 controller?
    Is it theoretically 512 clusters given that is the VPN client limit and the tunnel would only ever be established to one AP from each cluster at a time?
  • 2.  RE: 7005 IAP-VPN
    Posted Oct 11, 2017 08:51 PM
    Hi Chris_Denham,
    It would not be recommedned to use a 7000 series controller as a VPN concentrator for IAP-VPN.
    But for your reference please see the following.
    http://www.arubanetworks.com/techdocs/ArubaOS_65x_WebHelp/Web_Help_Index.htm#ArubaFrameStyles/IAP VPN Support/Overview.htm%3FTocPath%3DArubaOS%2520User%2520Guide%2520Topics%7CIAP%2520VPN%2520Support%7C_____1
  • 3.  RE: 7005 IAP-VPN
    Posted Oct 11, 2017 08:54 PM
    Thanks Matthew - what would you recommend instead?
    We are using this for 1-5 sites only and 2 SSIDs at each with fairly light utilisation.
