7005/7008 as branch controllers tunneling all the traffic to HQ?
  • 1.  7005/7008 as branch controllers tunneling all the traffic to HQ?
    Posted Nov 24, 2019 09:32 AM
    Is is possible to have 7005/7008 as a sort of "large RAP" where I tunnel everything from the branch controller back to the HQ? Or do the VLANs/SSIDs need to be "local" on the 700x and then do a VPN tunnel back. Is it possible to automatically carry all the VLANs to the HQ VPNC or do I manually need to configure each VLAN/IP subnet?
    Or is the only way to go to cloud managed SD-branch?
    Thanks!
  • 2.  RE: 7005/7008 as branch controllers tunneling all the traffic to HQ?
    Posted Nov 25, 2019 12:38 AM
    It is doable. Basically you just set up GRE/IPSec tunnels towards HQ. You can use policy-based routing to send some traffic directly to Internet from the branch site.
