7030 ap install
  • 1.  7030 ap install
    Posted Sep 27, 2016 01:51 AM
    On a 7030 I want deploy new ap managed by the mobility ciontroller. I set the dhcp server on the controller with 43 parameter, where the ip of controller is indicated. It doesn't work. The Ap take the ip address and the controller ip but after it elects him self as a master controller. The controller and the ap are on the same subnet and between them there is connection. If I use the web gui of the ap and go in Maintanance-Convert and I choose Campus Ap managed by a mobility controller and type the ip of controller, the ap reeboot and after connect to controller and works.
    What's wrong?  I think the dhcp doesn't give the right ip o configuration
  • 2.  RE: 7030 ap install
    Posted Sep 27, 2016 06:50 AM
    An Instant AP needs to be converted before it can work with a controller.  Option 43 will not work before it is converted
