Wired Intelligent Edge
716 idm: ACL error - insufficient policy engine resources
This thread has been viewed 40 times
  • 1.  716 idm: ACL error - insufficient policy engine resources
    Posted Oct 20, 2020 09:57 PM
    Trying to 801.x auth a printer into switch role called Printer.  CPPM is sending the correct role to the switch we do this configuration all the time.  This is on a 2930F switch with AOS WC.16.10.0009.  A show log shows an error.  I have a TAC case open but hoping for a quicker answer.  Any idea how I can fix this?  We use the same config on all our switches and I do not have this issue anywhere else on over 150 switches with the same configs.
    I 10/20/20 19:08:05 00076 ports: port 12 is now on-line
    I 10/20/20 19:08:05 00435 ports: port 12 is Blocked by AAA
    W 10/20/20 19:08:05 00716 idm: ACL error - insufficient policy engine resources, client 9C934EA86510, port 12
    show access-list resources
    Resource usage in Policy Enforcement Engine
    Ingress Policy Enforcement Engine Rules
    | Rules | Rules Used
    Ports | Available | ACL | QoS | IDM | VT | Mirr | PBR | OF | Other |
    1-52 | 3752 | 0 | 92 | 120 | 0 | 0 | 0 | 0 | 96 |
    Ingress Policy Enforcement Engine Meters
    | Meters | Meters Used
    1-52 | 2044 | | 0 | 1 | 0 | | | 0 | 2 |
    Ingress Policy Enforcement Engine Port Ranges
    |Application|
    |Port Ranges| Application Port Ranges Used
    1-52 | 56 | 0 | 3 | 0 | | 0 | 0 | 0 | 2 |
    Ingress Policy Enforcement Engine PBR Resources
    | PBR |
    | Next-hops | PBR Next-hops Used
    1-52 | 1024 | | | | | | 0 | | 0 |
    7 of 32 Policy Engine management resources used.
    Egress Policy Enforcement Engine Rules
    1-52 | 2032 | 0 | 0 | 0 | 0 | 0 | 0 | 0 | 0 |
    Egress Policy Enforcement Engine Meters
    1-52 | 1023 | | 0 | 0 | 0 | | | 0 | 0 |
    |Application|
    1-52 | 60 | 0 | 0 | 0 | | 0 | 0 | 0 | 0 |
    0 of 8 Policy Engine management resources used.
    Key:
    ACL = Access Control Lists
    QoS = Device & Application Port Priority, QoS Policies, ICMP rate limits
    IDM = Identity Driven Management
    VT = Virus Throttling blocks
    Mirr = Mirror Policies, Remote Intelligent Mirror endpoints
    PBR = Policy Based Routing Policies
    OF = OpenFlow
    Other = Management VLAN, DHCP Snooping, ARP Protection, Jumbo IP-MTU,
    RA Guard, Control Plane Protection, Service Tunnel, ND Snooping, UWW,
    mDNS, tunneled-node-server, copp, ICMP rate-limit,
    Unknown Unicast rate-limit.
    Resource usage includes resources actually in use, or reserved for future
    use by the listed feature. Internal dedicated-purpose resources, such as
    port bandwidth limits or VLAN QoS priority, are not included.
  • 2.  RE: 716 idm: ACL error - insufficient policy engine resources
    Posted Oct 22, 2020 04:27 AM
    Please let us know what TAC has found, such that others may learn from it.
  • 3.  RE: 716 idm: ACL error - insufficient policy engine resources
    MVP
    Posted Sep 21, 2022 12:09 PM
    Dig you ever get this 'resolved'?
    I am running into the same issue where I cannot believe we actually we ran out of resources (tiny ACLs, lightly loaded ACLs)... unless some process or the likes crashed/hung up/....
  • 4.  RE: 716 idm: ACL error - insufficient policy engine resources
    Posted Sep 21, 2022 02:38 PM
    Try to upgrade to the lastest firmware as I have found some references where that fixed the issue, if you still see it afterwards check with TAC what is using up your resources. I don't know the commands to find the limits and actual usage. TAC may also know a way to workaround, as I think not all ACLs/ACEs are the same, and some can be reused where others can't; but don't know the exact details.
  • 5.  RE: 716 idm: ACL error - insufficient policy engine resources
    MVP
    Posted Sep 22, 2022 06:16 AM
    In our case we are already running wc16.11.0006 and we first saw this issue on this release.
    I don't believe it is an actual resource issue. Not one caused be resource usage anyway. We only use a few small ACL and the switch is lightly loaded with users compared to other switches with exactly the same ACLs.
    If I interpret the output below correctly, line 22 says no resources are available while none are used?
    Userguide isn't too helpful either.
    Oh, and no foundation care so TAC won't look at the ticket.
                  |   Rules   |  Rules Used
    1/1-48,A      |      3842 |   0 |   0 | 208 |   0 |    0 |   0 |    0 |   266 |
    2/1-48,A      |      4052 |   0 |   0 |   0 |   0 |    0 |   0 |    0 |    56 |
    1/1-48,A      |      1782 |     |   0 |   1 |   0 |      |     |    0 |     0 |
    2/1-48,A      |         0 |     |   0 |   0 |   0 |      |     |    0 |     0 |
                  |Application|
    1/1-48,A      |        60 |   0 |   0 |   0 |     |    0 |   0 |    0 |     0 |
    2/1-48,A      |        60 |   0 |   0 |   0 |     |    0 |   0 |    0 |     0 |
                  |    PBR    |
    1/1-48,A      |      1024 |     |     |     |     |      |   0 |      |     0 |
    2/1-48,A      |      1024 |     |     |     |     |      |   0 |      |     0 |
                  |   Rules   |  Rules Used
    1/1-48,A      |      2032 |   0 |   0 |   0 |   0 |    0 |   0 |    0 |     0 |
    2/1-48,A      |      2032 |   0 |   0 |   0 |   0 |    0 |   0 |    0 |     0 |
    1/1-48,A      |      1023 |     |   0 |   0 |   0 |      |     |    0 |     0 |
    2/1-48,A      |      1023 |     |   0 |   0 |   0 |      |     |    0 |     0 |
    Egress Policy Enforcement Engine Port Ranges
                  |Application|
    Key:
    OF = OpenFlow
            Unknown Unicast rate-limit, IGMP filter unknown multicast.
  • 6.  RE: 716 idm: ACL error - insufficient policy engine resources
    MVP
    Posted Sep 23, 2022 11:55 AM
    For those running in to the same issue..
    Reboot of the affect stack member did NOT fix the issue.
    Reboot of the entire stack did resolve the issue.
  • 7.  RE: 716 idm: ACL error - insufficient policy engine resources
    Posted Jan 13, 2023 09:02 AM
    Thanks for this, we've also started to see this, on 2930F switches with AOS WC.16.11.0004.  I'll have to wait until can get a reboot in to test if the issue goes away (probably for a while I guess)
    I couldn't reproduce the issue in a lab - but that's probably because it was recently rebooted.
    Has anyone updated to WC.16.11.0008 and seen this issue go away?  I don't see anything in the release notes to suggest its been fixed...?
  • 8.  RE: 716 idm: ACL error - insufficient policy engine resources
    MVP
    Posted Jan 13, 2023 10:09 AM
    Workaround that worked for us: disable http fingerprinting
    We were also promised that the issue will be fixed in upcoming release i.e. 16.11.0009 which would be Tentatively release by End of Jan 2023
  • 9.  RE: 716 idm: ACL error - insufficient policy engine resources
    MVP EXPERT
    Posted May 19, 2023 03:59 AM
    Just seen this happening on our WC.16.10.21  2930 switches. GHiven the wC.16.11.11 is now out  do you kniow if its fixed?
    also would anyone know if there is a fix in the 16.10 firmeware branch ?
    A
  • 10.  RE: 716 idm: ACL error - insufficient policy engine resources
    Posted May 19, 2023 04:07 AM
    Hi, I can confirm we updated to WC.16.11.10 and that has been fine thus far.
    In the release notes we noted this as fixed:
    16.11.0010 256898 WC Symptom: Authentication fails due to an insufficient ACL resources error.
    Access ControlLists (ACL)
  • 11.  RE: 716 idm: ACL error - insufficient policy engine resources
    MVP EXPERT
    Posted May 19, 2023 04:49 AM
    Many thanks for the quick reply
    A
