7200&6000 CONTROLLER IN VRRP
  • 1.  7200&6000 CONTROLLER IN VRRP
    Posted Dec 13, 2012 03:14 PM
    I have an 6000 controller with 200 AP I want to buy a 7200 controller and configure it in HA.
    The 7200 it will be active and 6000 in Stand By.
    This is work? I have doubt about the new AppRF, this is only work on the 7200 controller?
    If the 7200 goes down what functionality I lost when the 6000 is in master when the 7200 goes down??
    Can someone help to figure out this?
    Thanks!
  • 2.  RE: 7200&6000 CONTROLLER IN VRRP
    Posted Dec 14, 2012 05:32 AM
    i believe AppRF is just a feature for ArubaOS 6.2 (though Aruba doesnt mention this in the release notes) and works on 3200xm (3200 with memory upgrade) and above controllers, so you should be fine with 6000, though the both have to be running 6.2 then.
  • 3.  RE: 7200&6000 CONTROLLER IN VRRP
    Posted Mar 27, 2013 11:41 AM
    it is indeed a feature of AOS 6.21 but you need the PEFNG license for AppRF.
