8.6.0.3 Editing VLAN Issue
  • 1.  8.6.0.3 Editing VLAN Issue
    Posted Mar 30, 2020 09:19 AM
    Looks like there is an issue with editing VLANS in the GUI on managed devices on Mobility Master on version 8.6.0.3. All the settings for existing VLANs are empty and I cannot edit them via the GUI. Even if I create a new VLAN and assign and IP address to it via the GUI, those settings are blank. I have to go to CLI to edit them.
    I opened a case with TAC but wanted to see if others that has upgraded to 8.6.03 has this issue.
  • 2.  RE: 8.6.0.3 Editing VLAN Issue
    Posted Mar 30, 2020 10:03 AM
    I see that the field is blank but you can still enter/edit/change the IP and mask. It should reflect that value in the table above.
  • 3.  RE: 8.6.0.3 Editing VLAN Issue
    Posted Mar 30, 2020 10:15 AM
    It is not doing so for me.
  • 4.  RE: 8.6.0.3 Editing VLAN Issue
    Posted Mar 30, 2020 11:25 AM
    Please open a TAC case to investigate further. I see the same behavior, but as Seth mentioned I can make and apply changes to the IP/netmask on the vlan interface. The changes still do not show ip in the WebUI, however can confirm they were applied via the cli.
  • 5.  RE: 8.6.0.3 Editing VLAN Issue
    Posted Mar 30, 2020 11:40 AM
    Case was already opened prior to posting here. Just wanted to see if others was having the same experience.
    Case 5346229506
  • 6.  RE: 8.6.0.3 Editing VLAN Issue
    Posted Mar 30, 2020 11:46 AM
    Thanks for the additional information. I'll take a look at the case info as well.
  • 7.  RE: 8.6.0.3 Editing VLAN Issue
    Posted May 06, 2020 09:39 AM
    Just wanted to followup that this has been fixed in version 8.6.0.5 that is due to be released sometime in June.
