  • 1.  9240 Gateway - Aruba OS 8 Clustering and License.
    Posted Mar 27, 2024 10:02 AM
    Hello all,
    Quick questions, can the 9240 be in the same cluster as a 7210 with the same Mobility Conductor?
    Also is there a license upgrade from silver to gold or does the customer need to buy gold now if in the future they want more than 1,024 APs?
    Jason
  • 2.  RE: 9240 Gateway - Aruba OS 8 Clustering and License.
    Posted Mar 27, 2024 10:10 AM
    We cannot mix 72xx and 92xx in the same cluster.
  • 3.  RE: 9240 Gateway - Aruba OS 8 Clustering and License.
    Posted Mar 27, 2024 10:56 AM
    Edited by chulcher Mar 27, 2024 10:56 AM
    Specifically, cannot mix 72xx and 92xx when running AOS 8.
    And there isn't a license to upgrade from silver to gold capacity levels.
    Carson Hulcher, ACEX#110
  • 4.  RE: 9240 Gateway - Aruba OS 8 Clustering and License.
    Posted Aug 13, 2024 12:27 PM
    Any details why 7210 cannot form cluster with 9240?
  • 5.  RE: 9240 Gateway - Aruba OS 8 Clustering and License.
    Posted Aug 13, 2024 12:36 PM
    For AOS 8, software support wasn't available for the mix.
