93h as Wired bridge
  • 1.  93h as Wired bridge
    Posted Mar 21, 2014 03:03 PM
     I am wondering if it is possible to connect a 93h as a mesh endpoint, and give the 4 wired ports network access via the mesh connection?
  • 2.  RE: 93h as Wired bridge
    Posted Mar 21, 2014 03:42 PM
    You should be able to accomplish this .
    If you already have your mesh link up and running the all you need to do is create a eth port config / wired ap and make the forwarding mode be bridge or split tunnel and apply the aaa profile with the assigned user-role already created and the VLAN those ports will use
  • 3.  RE: 93h as Wired bridge
    Posted Mar 21, 2014 06:27 PM
    Also would a RAP 155 be able to be converted to a CAP and be utilized in this same way?  I would love to be able to provide 2 Poe ethernet ports with a wireless backhaul for some locations.
  • 4.  RE: 93h as Wired bridge
    Posted Mar 21, 2014 07:23 PM
    I know the 155 can do mesh, but I don't think it can be converted to a campus AP. Only RAP or Instant.
