@cjoseph wrote:
1. You only need a single AT poe on port 0
2. are you supplying DHCP to that device?
Hi Colon,
Thank you for the quick reponse. I could only get the AP to go green on system status when I added 2 Arube 802.3 AT injectors. I will have to play with that a bit more.
On question #2. I am not suppying with DHCP, I have it connected to to 1Gb ports configured in a LACP configuration. The default VLAN does not have DHCP on it. My PC get an IP address of 172.31.98.232, with a netmask of 255.255.254.0 and default gateway of 172.31.98.1 When I try to browse to 172.31.98.1, the browser gets redirected to https://instant.arubanetworks.com:4343/. Unfortunately when I do a nslookup or ping it they both report ther is no DNS for instant.arubanetworks.com.
Thank you, I as trying to get this setup in my while I have a 3 day weekend.
Bryan
