this is the controller after upgrading the Firmware to 6.1.3.1 as u can see i have marked 3 IAPs they are in the same place to fulfill about 80 users also all IAPs channles and Power are automticlly controled by the VC but as u can see two of them have the same channel which will make interferance and brining down the wireless network
Note:-
at info the VC name is "Aruba master" but the "IAP of the VC IP "name is aruba apple is this a problem in configuration also here is the configuration:-
version 6.1.3.0-3.0.0
virtual-controller-country EG
virtual-controller-key 2fddcaab0122e1e4f953d81c68e231fa8549ea8c61acf552e9
name "Aruba master"
virtual-controller-ip 172.27.2.57
ntp-server ntp.org
clock timezone Cairo 02 00
rf-band all
allow-new-aps
allowed-ap d8:c7:c8:cf:c8:44
allowed-ap d8:c7:c8:cf:c7:9c
allowed-ap d8:c7:c8:cf:c7:76
allowed-ap d8:c7:c8:cf:c7:bf
allowed-ap d8:c7:c8:cf:c7:b3
allowed-ap d8:c7:c8:cf:c8:09
arm
wide-bands 5ghz
min-tx-power 18
max-tx-power 127
band-steering-mode prefer-5ghz
air-time-fairness-mode fair-access
client-aware
scanning
syslog-level warn ap-debug
syslog-level warn network
syslog-level warn security
syslog-level warn system
syslog-level warn user
syslog-level warn user-debug
syslog-level warn wireless
mgmt-user admin 2c440ebe90a2e32a4bb8b4e1888657ce0ab143774c960e19
wlan ssid-profile "Almasry Alyoum"
index 0
type employee
essid "Almasry Alyoum"
wpa-passphrase ce1c46c7ec2bc530ce85305ee5c50acd5a8b3ce6d675ab22
opmode wpa-psk-tkip,wpa2-psk-aes
max-authentication-failures 0
rf-band all
captive-portal disable
dtim-period 1
inactivity-timeout 1000
broadcast-filter none
blacklist
enet-vlan guest
wlan access-rule default_dev_rule
index 0
rule any any match any any any permit
wlan access-rule "Almasry Alyoum"
index 1
wlan access-rule test
index 2
wlan external-captive-portal
server localhost
port 80
url "/"
auth-text "Authenticated"
blacklist-time 3600
auth-failure-blacklist-time 3600
ids
wireless-containment none
wired-port-profile default_wired_port_profile
switchport-mode trunk
allowed-vlan all
native-vlan 1
shutdown
access-rule-name default_dev_rule
speed auto
duplex full
no poe
enet1-port-profile default_wired_port_profile
enet2-port-profile default_wired_port_profile
uplink
preemption
enforce none
