A mobility domain with more than 16 controllers
  • 1.  A mobility domain with more than 16 controllers
    Posted Jul 05, 2013 11:02 AM
    Hello all,
    What is the problem if a mobility domain has more than 16 controllers?
    I found the command “show global-user-table list” will not work.  Beside the GUT, will I have any problems with the performance of my WLAN?
    (MASTER) #show global-user-table list
    GUT not available if more than 16 Local Controllers are connected to the master
    My AOS is 6.1.3.8
  • 2.  RE: A mobility domain with more than 16 controllers
    Posted Jul 08, 2013 01:18 PM
    Please open a case with TAC to understand if there are any restriction on global-user table list output.
    We could also check with Engineering team on that however this shouldnt impact on any WLAN perfomance issue as such.
    Thanks & Regards
    Sriram Subramanian
    Techincal Support Engineer
    srirams@arubanetworks.com
    408.585.1928
  • 3.  RE: A mobility domain with more than 16 controllers
    Posted Jul 08, 2013 03:37 PM
    Thanks Sriram.  I got a blessing from TAC.  It should be no performance issue.  Hopefully engineer will fix the GUT
