A way to display AP's upstream switch port
  • 1.  A way to display AP's upstream switch port
    Posted Apr 10, 2015 02:20 PM
    Does anyone know of a report or a filter view in AirWave that will show the switch port that an AP is connected to? I can get the AP's MAC address-to-switchport mapping info from the CLI, but I also have a filter view set up in AirWave that includes the AP name and MAC - it would be great if that view could also include the switchport that the AP connects to.
    Thanks.
  • 2.  RE: A way to display AP's upstream switch port
    Posted Apr 10, 2015 03:16 PM
    Think I have something that will work (at least for my purposes): in the MAS web GUI, under 'Dashboard', you can go to 'Neighbor Devices' and find a mapping of MAC address to switch port to System Name, which is pretty much what I was after. You can sort or filter on those columns to narrow it down to what you want to see.
  • 3.  RE: A way to display AP's upstream switch port
    Posted Jul 09, 2015 01:25 PM
    I am also curious about this - we need to do an audit of our documentation after a recent install and I see that you can list out the upstream device  in the device view, but it doesn't seem that you can specify the port of that device. This would save us a lot of manual audit time if there was a way to view/report on this from Airwave....
    Thanks.
  • 4.  RE: A way to display AP's upstream switch port
    Posted Jul 16, 2015 04:33 PM
    Disclaimer- this may not be the safest or most efficient method, but it works
    LLDP Neighbor info can be found in the output of show ap tech-support ap-name "apname"
    You can use AirRecorder (from the Aruba utilities page) to dump this info to a file. Then grep for relevant lines or filter in Excel.
