Developer
A10 RBAC Clearpass
This thread has been viewed 32 times
  • 1.  A10 RBAC Clearpass
    Posted Mar 24, 2022 08:31 AM
    I need two access profiles, one read/write and the other read only, for all partitions. With the A10 dictionary, it does not allow granting those levels of permissions, to differentiate by partitions.
    How can an administrator be allowed to access multiple partitions on A10?
    To authorize an administrator to access multiple partitions, I think you have to use the RADIUS syntax:
    A10-Admin-Partition = "partition-name1"
    A10-Admin-Partition += "partition-name2"
    A10-Admin-Partition += "partition-name3"
    A10-Admin-Partition += "partition-name4"
    But it doesn't work on Clearpass, is there any other way?
  • 2.  RE: A10 RBAC Clearpass
    MVP GURU
    Posted Mar 31, 2022 04:22 AM
    Hi jjb
    i think it is the wrong section.
    Do you have check if there is the A10 dicto on ClearPass
    PowerArubaCL: Powershell Module to use Aruba Central
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: A10 RBAC Clearpass
    Posted Apr 19, 2022 12:08 AM
    Device users will be in sync with Harmony Controller through the device registration process but no default role will be given to these users. Super-admin or any provider admin will have to manually associate the role with the users.
    My HT Space
    Mary Houck
