A200 Image not present
  • 1.  A200 Image not present
    Posted Jun 10, 2013 01:12 PM
    I format my compact flash to do a clear installation of the latest firmware :
    CPBoot 1.2.11 (build taylor@harpua-ENG.0000)
    Built: 2005-09-13 17:38:55 (with gcc 2.95)
    CPU:   MPC8245 Revision 16.20 at 199.999 MHz: 16 kB I-Cache 16 kB D-Cache
    Board: Malbec Local Bus at 99.999 MHz
    DRAM:  256 MB
    POST:  passed
    CPLD:  Revision 4
    FLASH: 512 kB
    PCI:   scanning bus0 ...
           dev fn venID devID class  rev MBAR0    MBAR1    MBAR2    MBAR3
           00  00 1057  0006  060000 14  00000008 00000000 00000000 00000000
           14  00 166d  0001  060000 03  f0000008 00000000 f1000008 f1001008
           15  00 177d  0003  100000 00  00000001 00000000 00000101 00000000
    IDE:   Bus 0: OK
           Device 0: Model: CF 256MB Firm:  Ser#: 2010C     0000017750
                Type: Removable Hard Disk
                Capacity: 250.7 MB = 0.2 GB (513536 x 512)
    Net:   sibyte#0
    Hit any key to stop autoboot:  0
    0:0 Image not present
    0:1 Image not present
    0:2 Image not present
    cpboot>
    To transfert this firmware I set up my environement like this :
    cpboot> printenv
    bootcmd=boot flash
    bootdelay=2
    baudrate=9600
    serverip=192.168.1.18
    ipaddr=192.168.1.19
    netmask=255.255.255.0
    gatewayip=192.168.1.1
    stdin=serial
    stdout=serial
    stderr=serial
    but when i try to ping my tftp server I have :
    cpboot> ping 192.168.1.18
    ARP broadcast 1 for 192.168.1.18
    sibyte#0: tx buffer not transmitted
    ARP broadcast 2 for 192.168.1.18
    sibyte#0: tx error, buffer not ready
    In the uartb config after configuring eth0
    npboot> ifconfig eth0 -addr=192.168.1.19 -mask=255.255.255.0
    Device eth0:  hwaddr 40-00-10-06-40-00, ipaddr 192.168.1.19, mask 255.255.255.0
            gateway not set, nameserver not set
    *** command status = 0
    npboot> ping 192.168.1.18
    192.168.1.18 (192.168.1.18) is alive
    192.168.1.18 (192.168.1.18): 1 packets sent, 1 received
    I try to load the firmware using :
    npboot> load -tftp 192.168.1.18:A200_5.0.4.12_38448
    Loader:raw Filesys:tftp Dev:eth0 File:192.168.1.18:A200_5.0.4.12_38448 Options:(null)
    Loading:
    ........... 262144 bytes read
    Entry at 0x0000000020000000
    but it's doesn't work. Is anyone have the good procedure to help me to make my a200 working please ?
  • 2.  RE: A200 Image not present
    MVP EXPERT
    Posted Jun 11, 2013 03:05 AM
    How exactly did you format the compact flash?
  • 3.  RE: A200 Image not present
    Posted Jun 11, 2013 03:22 AM
    I format the card using in command line via serial câble
    cpboot>format
    cpboot>part 0
    cpboot>reset
