Comware
A5500 - DHC Relay & VLANs
  • 1.  A5500 - DHC Relay & VLANs
    Posted Oct 19, 2012 05:15 AM
    Morning guys,
    still working on my A5500 and now that the IRF is working fine I'd like to confirm/check some things before doing something wrong.
    First of all : VLANs
    I will have 4 1910 switches connected with LACP to my 5500 stack.
    On each 1910 I will have several VLANs configured ....all carried by the 5500s.
    1 - I assume that I shall configure the VLAN/VLAN interface on the 5500 and then configure the ports on the 1910 to match the existing VLANs created on the core. I am right here?
    2 - I see the words "hybrid", "tagged" and "untagged". What does hybrid stands for? If a port is untagged on VLAN 1on the 1910...will the 5500 be able to route the traffic coming from VLAN 2 to the VLAN 1?
    I assume that I have to tag every vlan on every 1910 port wich have an LACP uplink to the 5500...but want to check with you folks.
    DHCP Relay :
    I will create one DHCP pool for each VLAN I have on my DHCP server to provide each subnet with a proper IP@ and my 5500 will be the DHCP-Relay.
    1 - Should I enable the DHCP snooping on the 5500 & 1910? [dumb question....]
    2 - Will that be a problem to have all the subnets redirected to the same DHCP server by the 5500?
    Many thanks to you all!
    Armahir
    #VLAN
    #DHCP
  • 2.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 19, 2012 11:38 AM
    1) Yes
    2) The ports between the 5500 and 1910 should be mode trunk (tagged). Hybrid is a mode where you can have more than 1 untagged vlan on a trunk, kind of confusing. But trunk it is.
    1) Depends. If you will have clients/users connected to the 5500 then both. Otherwise just the 1910.
    2) Thats no problem, the server will know which IP do give out based on the IP of the relayed vlan.
    #DHCP-relay
    #VLAN
    #DHCPRelays
  • 3.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 20, 2012 04:56 AM
    Hey Fredrik,
    thank you very much for your concise answer!
    If I'm correct it's the second time you help me out of trouble :)
    Just have a last question though : port on 1910 AND 5500 should be tagged [link between IRF stack & 1910]?
    I'll do the conf' now for test-environment and let you know how it goes!
    Cheers & enjoy your WE!
    Armahir
  • 4.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 20, 2012 05:41 AM
    I hope everything goes as planned :). Yes the link between the 5500 stack and the 1910 should be tagged if you have multiple VLANs spanning over it.
  • 5.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 05:53 AM
    Ola!
    Everything went as planned....but not quite :)
    Actually thing is I have 2 VLANs [100 & 101] on a 1910 and the VLAN interfaces are on my 5500.
    PVID on ports between the 1910 and 5500 is 1
    Ports are tagged 100 & 101
    Vlan1 - 1910 IP@ : 10.10.10.1 /24
    Vlan1 - 5500 IP@ : 10.10.10.254 /24
    They both ping each other with I have the following issue for my other Vlans.
    In a few word :
    On 5500:
    VLAN interface 100 : 192.168.100.254
    Port 1 HYBRID Tagged 100 -101 / untagged 1
    OSPF : 192.168.100.0 /24 directly connected - Nexthop is Interface vlan 100 on 127.0.0.1
    On 1910 :
    Vlan 100 is created without an interface
    Port 24 access vlan 100
    Port 1 HYBRID tagged 100 - 101 / untagged 1
    Computer plugged on port 24 [IP 192.168.100.1 /24]
    Computer can ping the Gateway on the 5500......but 5500 can not ping the computer.
    I'm a bit lost here...
    Do you have a clue? :)
    Is the Hybrid mode the issue? [does not make sens to me]
    EDIT : Yes was hybrid...I'm dumb.... :=)
    EVERYTHING IS NOW FINE!!!
    Cheers!
    Armahir
  • 6.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 08:38 AM
    Actually.....It's failing again.
    I can ping all my VLAN interfaces on my 5500 from all my VLANs but the 5500 does not forward traffic from a VLAN to another....
    Help still needed :)
    Many thanks.
    Armahir
  • 7.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 09:39 AM
    PCs got the 5500 as default gateway? Can you post a display route from the 5500.
  • 8.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 09:52 AM
    Yes, PCs have their Vlan interface on 5500 as their gateway [and so default route on route print].
    Dis route on my 5500 does not show anything....
    Here's the 5500 conf :
    [sysname] dis cur
     version 5.20, Release 2208P01
     sysname Romeo
     super password level 3 cipher xxxxxxxxxxxxxxxxxxxxxxx
     ftp server enable
     dhcp relay server-group 1 ip xxxxxxxxxx
     irf mac-address persistent always
     irf auto-update enable
     undo irf link-delay
     irf member 1 priority 32
     domain default enable system
     telnet server enable
     ip http acl 2001
     multicast routing-enable
    acl number 2001
     rule 0 permit
    igmp-snooping
    vlan 1
     description DOWNLINK
     ip-subnet-vlan 0 ip 10.10.10.0 255.255.255.0
    vlan 2 to 99
    vlan 100
     description ADMIN
     name ADMIN
     ip-subnet-vlan 0 ip 192.168.100.0 255.255.255.0
    vlan 101
     description xxxxxxxxxx
     namexxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.101.0 255.255.255.0
    vlan 102
     name xxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.102.0 255.255.255.0
    vlan 103
     name xxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.103.0 255.255.255.0
    vlan 104
     name xxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.104.0 255.255.255.0
    vlan 105
     name xxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.105.0 255.255.255.0
    vlan 106
     name xxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.106.0 255.255.255.0
    vlan 107
     name xxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.107.0 255.255.255.0
    vlan 108
     description GUEST-WIFI
     name GUEST
     ip-subnet-vlan 0 ip 192.168.108.0 255.255.255.0
    vlan 109
     name xxxxxxxxxx
     ip-subnet-vlan 0 ip 192.168.109.0 255.255.255.0
     igmp-snooping enable
    vlan 110 to 199
    vlan 200
     name xxxxxxxxxxv
     ip-subnet-vlan 0 ip 192.168.0.0 255.255.255.0
    vlan 201 to 4094
    radius scheme system
     primary authentication 127.0.0.1 1645
     primary accounting 127.0.0.1 1646
     user-name-format without-domain
    domain system
     access-limit disable
     state active
     idle-cut disable
     self-service-url disable
    user-group system
    local-user admin
     password cipher xxxxxxxxxxxxxxxxxxxx
     authorization-attribute level 3
     service-type lan-access
     service-type ssh telnet terminal
     service-type ftp
     service-type portal
    user-profile admin
    interface NULL0
    interface Vlan-interface1
     ip address 10.10.10.254 255.255.255.0
    interface Vlan-interface100
     description ADMIN
     ip address 192.168.100.254 255.255.255.0
    interface Vlan-interface101
     ip address 192.168.101.254 255.255.255.0
    interface Vlan-interface102
     ip address 192.168.102.254 255.255.255.0
    interface Vlan-interface103
     ip address 192.168.103.254 255.255.255.0
    interface Vlan-interface104
     ip address 192.168.104.254 255.255.255.0
    interface Vlan-interface105
     ip address 192.168.105.254 255.255.255.0
    interface Vlan-interface106
     ip address 192.168.106.254 255.255.255.0
    interface Vlan-interface107
     ip address 192.168.107.254 255.255.255.0
    interface Vlan-interface108
     ip address 192.168.108.254 255.255.255.0
    interface Vlan-interface109
     ip address 192.168.109.254 255.255.255.0
    interface Vlan-interface200
     ip address 192.168.0.253 255.255.255.0
    interface GigabitEthernet1/0/1
     port link-mode bridge
     port link-type trunk
     port trunk permit vlan all
    interface Ten-GigabitEthernet1/1/1
    interface Ten-GigabitEthernet1/1/2
    interface Ten-GigabitEthernet2/1/1
    interface Ten-GigabitEthernet2/1/2
    ospf 1
     enable link-local-signaling
    ospfv3 1
    igmp
     snmp-agent
     snmp-agent local-engineid 800063A203B8AF67DD8C2D
     snmp-agent sys-info contact IT
     snmp-agent sys-info location LTE
     snmp-agent sys-info version v3
    Am i missing something?
    Plus, on the 1910 I can't access the management mode via CLI [_cmdonline-mode on does not take my super password] so I've made port 1/0/1 on 1910 trunk + tagged for vlan 2-201
    Edit :
    On 5500 HTTP interface in IPv4 routing I see all my vlan interfaces ==>
    10.10.10.0 255.255.255.0 Direct 0 10.10.10.254 Vlan-interface1
    10.10.10.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    127.0.0.0 255.0.0.0 Direct 0 127.0.0.1 InLoopBack0
    127.0.0.1 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.0.0 255.255.255.0 Direct 0 192.168.0.253 Vlan-interface200
    192.168.0.253 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.100.0 255.255.255.0 Direct 0 192.168.100.254 Vlan-interface100
    192.168.100.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.101.0 255.255.255.0 Direct 0 192.168.101.254 Vlan-interface101
    192.168.101.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.102.0 255.255.255.0 Direct 0 192.168.102.254 Vlan-interface102
    192.168.102.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.103.0 255.255.255.0 Direct 0 192.168.103.254 Vlan-interface103
    192.168.103.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.104.0 255.255.255.0 Direct 0 192.168.104.254 Vlan-interface104
    192.168.104.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.105.0 255.255.255.0 Direct 0 192.168.105.254 Vlan-interface105
    192.168.105.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.106.0 255.255.255.0 Direct 0 192.168.106.254 Vlan-interface106
    192.168.106.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.107.0 255.255.255.0 Direct 0 192.168.107.254 Vlan-interface107
    192.168.107.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.108.0 255.255.255.0 Direct 0 192.168.108.254 Vlan-interface108
    192.168.108.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
    192.168.109.0 255.255.255.0 Direct 0 192.168.109.254 Vlan-interface109
    192.168.109.254 255.255.255.255 Direct 0 127.0.0.1 InLoopBack0
  • 9.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 10:34 AM
    Sorry, the command is "display ip routing-table"
    Remove all the ip-subnet-vlan from the VLANs, its not needed for intervlan routing, might mess things up.
  • 10.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 10:57 AM
    No worries :)
    All ip-subnet-vlan REMOVED.
    Here's the output of dis ip routing-table :
    [Romeo]dis ip routing-table
    Routing Tables: Public
            Destinations : 26       Routes : 26
    Destination/Mask    Proto  Pre  Cost         NextHop         Interface
    10.10.10.0/24       Direct 0    0            10.10.10.254    Vlan1
    10.10.10.254/32     Direct 0    0            127.0.0.1       InLoop0
    127.0.0.0/8         Direct 0    0            127.0.0.1       InLoop0
    127.0.0.1/32        Direct 0    0            127.0.0.1       InLoop0
    192.168.0.0/24      Direct 0    0            192.168.0.253   Vlan200
    192.168.0.253/32    Direct 0    0            127.0.0.1       InLoop0
    192.168.100.0/24    Direct 0    0            192.168.100.254 Vlan100
    192.168.100.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.101.0/24    Direct 0    0            192.168.101.254 Vlan101
    192.168.101.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.102.0/24    Direct 0    0            192.168.102.254 Vlan102
    192.168.102.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.103.0/24    Direct 0    0            192.168.103.254 Vlan103
    192.168.103.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.104.0/24    Direct 0    0            192.168.104.254 Vlan104
    192.168.104.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.105.0/24    Direct 0    0            192.168.105.254 Vlan105
    192.168.105.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.106.0/24    Direct 0    0            192.168.106.254 Vlan106
    192.168.106.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.107.0/24    Direct 0    0            192.168.107.254 Vlan107
    192.168.107.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.108.0/24    Direct 0    0            192.168.108.254 Vlan108
    192.168.108.254/32  Direct 0    0            127.0.0.1       InLoop0
    192.168.109.0/24    Direct 0    0            192.168.109.254 Vlan109
    192.168.109.254/32  Direct 0    0            127.0.0.1       InLoop0
  • 11.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 11:12 AM
    That looks about right. Did the removal of ip-subnet-vlan make any difference?
  • 12.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 11:16 AM
    Nope....unfortunatly.
    It's really wierd.
    My two computers are on the same 1910, wich is connected to the 5500, but cant ping each other.
    Basically :
    Computer 1 [VLAN100] can ping his gateway on the 5500, can ping ALL the other gateways on the 5500....put can't ping Computer 2 [VLAN200].
    Can't the issue come from the 1910?
  • 13.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 11:19 AM
    1910 could be the issue, but I cant really see how. If you are able; connect the end-point PCs directly in the 5500 to rule out the 1910.
  • 14.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 11:29 AM
    Issue is indeed on 5500.
    Computer 1 / VLAN 100 / Port 24 / Untagged
    Computer 2 / VLAN 200 / Port 23 / Untagged
    I can still ping all the gateways....but not from a computer to an other...
    I heard something about 802.1q encapsulation, what is it? do our issue could be related to that?
  • 15.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 11:37 AM
    Make 100% sure that the 5500 is the default gw of the computers, and also of course disable firewall if you're running windows :).
    802.1q encapsulation is what's used on trunks.
  • 16.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 21, 2012 11:39 AM
    Never applied that on my trunks :)
    How can I do that?
    I can confirm that the gateway on my computers are ok [all pointing to their respective vlan interface on 5500] and that I have disabled this f***** MS firewall ^^.
  • 17.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 23, 2012 10:05 AM
    Hi there,
    just to let you know that I've rebooted the switches [5500] and that all is now well.
    Weird, but like someone said before me : "In doubt, reboot".
    A lot of thanks to you Fredrick!!
    Cheers!
    Armahir
  • 18.  RE: A5500 - DHC Relay & VLANs
    Posted Oct 23, 2012 11:56 AM
    Heh weird. Well, good to hear everything worked out :)
